Question about Technics SL-1210MK5 Turntable
I didn't touch the pitch adj control, i didn't touch the reset button, i just put on a record press play then it run sometime fast and slow and fast and slow and..
  • Rob Beech May 11, 2010
    These are Quartz direct drive units. Does the pitch control still alter the pitch?
    I'd advise contacting your local Technics service centre for repair.
  • 515 Answers
This is an issue with the main drive circuits. You have what we call the 'washing machine' affect.
Only a qualified technican can repair this for you. Not too costly, if the tech knows what to look for. If not, then he will spend many wasted hours trying to find the damaged circuits. Make sure you explain the issue to them and ask if they've fixed it before.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
How get fast or slow speed when record music woice recorder
If the used recorder doesnt provide these filters from default...choose any audio editing app to play with the recorded audio file speed or pitch as u like.
Dec 14, 2017 | Audio Players & Recorders
Even though i am playing my record on normal speed, it plays to fast
if your turntable doesn't have a pitch control (like the dj's turntables) if you open it you should find on the board close from the 45-33 rpm switch a variable resistor ( a small electronic part with a sort of disc on top with in the middle of it a place for a flat screw driver and marking like + and - those resistor are made to control the speed and can go bad or just need to be adjusted . First try to adjust it turning the dial really carefully with a small screw driver if nothing happened it could need to be replace.
Feb 03, 2013 | Mutant MIG-MT201 Record Turntable, 33...
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
Playing podcasts fast
With podcasts on the ipod touch you can vary the speed of play. From normal speed to 1.5 times, 2 times and half speed. Just under the play indication is a button which is probably reading 1.5x or 2x press this button and you will be able to change the speed back to 1x. Hope this helps.
Mar 18, 2010 | Apple iPod touch
When play is punched in either direction it want move,not even in
yes, one nice overhaul will fix..(this can be done by you if you are daring...when u open take apart you will find a metal strip like band..I had used a bandaid for brakes the gauze side) you need new brakes (just like a car it is run down) on the reels in order for it slow & stop when it suppose to...or you can search and find a good old fashion repairman..(sorry I dont know of none)...for dragging, before playing all open reels fast fwd to one end then rewind it back to the beginning now hold the blank reel with that little bit catch tape try to tighten full side tape by going slightly going the other way not trying to stretch nor pop the tape.....now press play
Aug 07, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
PITCH CONTROL PROBLEM
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
- TERMiNAL OPTiC
www.DJPROLAB.com
Apr 01, 2008 | Technics SL-1200M3D Turntable
I have a 1200 technic turntable mk2
some times static charge fomr your hands or other things make this happen...don't touch the pole in the middle while speeding it up or slowing it down...if you mixing tracks...either shove the record or touch the edge of the platter...touching the pole send statis from your hands down the pole to the motor and it just takes off...I have been djing for ten years and in the begining it happend to me...
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Technics SL-1210MK5 Turntable Logo
219 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
