Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30GB won't charge in car.
Zune charges fine from wall charger and usb port, but not in my car. Phone and GSP charge fine from same car plug. I purchased a new battery and car charger, still does not charge. Antone else have the same problem?
prllbob
    Scholar:
  • 145 Answers
Some auto usb cables aren't compatable with Zune device.
Posted on Jun 02, 2009
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
I have a 30g Zune which has not been holding a charge for a couple of weeks. This morning the Zune powers up and then shuts off (even while plugged in). I tried the 'hold down the back button and up at the...
I am not sure if this is gonna work but, since you've tried all other steps why dont we give this a try too...LOL :-)
To troubleshoot this issue, try one or more of the following methods in the order in which they are listed:
  1. Let your Zune device charge for 30 minutes, then disconnect and reconnect the cable to turn on the player. It can take up to 3 hours to fully charge.
  2. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
  3. Use another supported high power source, such as an Xbox 360 console, a Zune AC Adapter, a Zune Car Charger, or a Zune FM Transmitter/Charger.
    Note These devices are sold separately.
  4. If you are connecting your Zune device to a mobile computer, make sure that the mobile computer is plugged in and is not running on battery power. Many mobile computers are configured to conserve power when they are running on battery power to extend battery life. This behavior may affect Zune device charging.
  5. If the Zune device is charging slowly, be aware that, for optimal charging, the Zune device requires at least 500 milliamps (mA) of power. Frequently, USB ports that are located on the front of a computer and on some USB hubs are low-power, 100-mA ports. Typically, the high-power, 500-mA USB ports are on the back of the computer. Additionally, when you suspend the computer or put the computer to sleep, high-power USB ports may be switched to low-power, 100 mA mode.
  6. If the device boots to the home screen but is still not charging correctly, continue with the "Home screen is displayed" steps in the following section.
    If the device continues to display the full-screen charging icon, continue with "Full-screen charging icon is displayed."
  7. If the battery in the device still does not charge correctly, visit the following Web site to sign in and register your device: http://service.zune.net (http://service.zune.net)
    At this Web site, you can submit a request for service if your device qualifies for service.
Dec 24, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it.
the zune does this if the battery doesn't work (needs a charged battery to power on). battery is either defective or disconnected. there is a zune repair guide that shows you how to fix it
Apr 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Charging
same as it does on the usb... the Zune can only handle the 5.5V(I think that's the voltage on usb ports...) so the wall chargers have to have that voltage rating...
Mar 04, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune 30GB Brown charging problem
heres a solution, i guess my freinds were right, i wish they werent , but i guess ZUNE'S ARE ****. Sorry Microsoft aint do that again.
Dec 28, 2007 | Microsoft Zune JS8-00001 Digital Media...
First time chargin Zune 30GB Brown
I had the same problem (frozen after first time trying to charge.) I found the solution on another site. I just unplugged the device and let the battery drain completely, then plugged it back in (rear usb port) and voila, it works, that simple.
Nov 30, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
133 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
