Question about Timex Watches
The crown and pushers of my timex e-compass looks different
The lower pusher of my timex e-compass looks different from the pictures displayed in the internet, i bought the watch from a legitimate timex store in the philippines
  • 2,334 Answers
Design of watch cases, pushers e.t.c. are changing quite rapidly, but this do not affect the functions of the watch, as the different looking cases can house the same movement. So, do not be worry about the different looks, because you may have one of the older (or even newer) designs. Just make sure your watch is functional and keeps good time. If it does- forget about the rest and wear it happily ever after.
Do not forget to rate, please.
Posted on Mar 07, 2009
My Timex Chicago watch just arrived, it works perfectly, but the chronograph second hand is not pointing at the 12th o'clock mark. Is there a way to fix that?
normally the watch chrono hands can be reset .
dependant on movement fitted.
*pull crown out to first position
* push and hold top right pusher.
* the second should start top sweep one complete revolution and then stop.
*when it stops use the lower right pusher to adjust.
*when at the 12 push the crown but in fully.
Aug 28, 2017 | Timex Watches
Stuck button on timex ironman watch
This is usually caused by dirt around the button sticking it into the hole. Try a drop of olive oil and turn the button gently or work it in and out until it loosens. I'm assuming this hasn't occurred immediately after a back removal? if so then the movement may have dislodged and the pusher may be on the wrong side of the contact. If this is the case remove the back and then the movement, push all of the buttons from the inside out to their furthest positions. carefully reinsert movement pushing each contact on the movement in turn as you lower that corner so as not to catch it on the pusher.
May 24, 2014 | Timex Watches
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
I have a bretling colt quartz watch and the hour regester will not reset
Try pulling out the winding crown,then press the chrono pusher.This will advance the chrono hands.Each pusher will advance a different hand.
Aug 13, 2010 | Breitling Colt Quartz 820 Wrist Watch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
I have a stainless steel wittnauer watch with chronograph and instead of being set on the :30 mark, it is set on the :01 mark on the stopwatch. i need it back to :30
Pull out crown and press and hold one of the pushers (depends on a movement model). Try till you see chrono hand moving and reset it by using correct pusher. Every time you try a different pusher - push crown in, then pull out and try again.
Rate me, please.
Jul 28, 2009 | Wittnauer Watches
Set Timex chronograph to zero
To adjust the chronogragh hands:
Pull the crown out to the "B" position (Timex defines the "A" position as all the way in, "B" as half way out and "C" as all the way out).
Press "Pusher B" (the button at the 4 o'clock position) repeatedly until the hand in the "10 o'clock eye" is at the 30 min (straight up) position.
Pull the crown out to the "C" position.
Press "Pusher A" (the button at the 2 o'clock position) repeatedly until the second hand resets to the "0" (or "60" or "12 o'clock") position.
Press "Pusher B" repeatedly until the hand in the "2 o'clock eye" is in the "0" (straight up) position.
Push in the crown all the way to the "A" position.
This has worked sucessfully on both my T2M467 and T2M552.
Dec 30, 2008 | Watches
Timex Ironman
Please press all pusher at same time, it will restart the ic, it's just like to restart your computer.
Jan 27, 2008 | Timex Sports Ironman Triathlon 100-Lap...
Watches Logo
50 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
