Question about La Pavoni Lusso PL-16 Espresso Machine
Our La Pavoni Lusso machine has not been used for a couple of months. We put water in to prime the pump, and nothing comes out. We can hear the pump going, and the heater indicator light is working. Any ideas? We dont' want to keep it on for fear of damaging the pump.
  • Sulejman Sulejmani
    Sulejman Sulejmani May 11, 2010
    1. you can hear the pump. it is good begining but do she change the voice of wotrking after 10 - 15 seconds?? do she works more quiet than?? or she works in same range all the time??
    Scholar:
  • 36 Answers
Try opening the steam nozzle while trying to pump the water through as this will get rid of any air locks. Otherwise it may be a build up of scale in the boiler or the pump itself. Try that and descale if you can.
All the best
LaPavoniBoy
Posted on May 28, 2009
La pavoni slow water flow
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
Feb 05, 2017 | La Pavoni Coffee Makers & Espresso...
Hi there. problem with my La pavoni PL-16. No coffee comes out. The vapour its ok, it comes out but from the place the coffee should comes out, it doesnt. With or without the the filter holder. Whats...
Hi if there is Vapor coming from the grouphead when the lever is down then I would guess there is a problem with the seals around the piston and possibly elsewhere. Here is a link to a goos site that looks at repairing La Pavoni lever machines. Good luck.
DIY
dr pavoni
May 29, 2014 | La Pavoni Lusso PL-16 Espresso Machine
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Pavoni pressure switch
Do you mean the safety valve to the right of where you put the water in a chrome dome top nut thing?
I you are happy to have a go and have the right sized spanner this is a possibly easy fix or really most likely a clean.
I did this a few months ago and it took a couple of minutes.
I undid it carefully removed all the parts cleaned off the limescale and reassembled it.
If you mean the pressurestat here is a link to a great site that show you what needs to be done and you can judge for yourself if you are up to it.
http://www.francescoceccarelli.eu/La_Pavoni/Faidate/pressostato_eng.htm
This site has loads on fixing these lovely machines.
All the best
Pierssy
Mar 16, 2014 | La Pavoni Coffee Makers & Espresso...
Hi can you tell me how to reset the safety thermostat on a La Pavoni EBR. The instruction manual tells you to do this but does not show you where it is or how to do it! Rob Burd
Hi Rob,
Open the top of the machine. On the heater element you'll see 8 cable connection: 2 on one end, 3 pairs on the other. The safety reset thermostat is on the middle of the 3 pairs (easy to spot the other 2 is flat, the middle one has a 2mm part sticking out). Remove that pair of cables - just in case - and push that button in. You'll hear a clicking noise. Connect the two cables back to the element and follow the "starting up procedure" from your manual. If you did everything correctly the machine will start to operate. Turn it off and put back the top. That should be it.
Dec 09, 2010 | La Pavoni Lusso PL-16 Espresso Machine
La pavoni
Remove the bottom panel and check the thermostats and element.
Jul 06, 2010 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Espresso comes out of comes out of spout before handle is raised
Hi there, i am Mr La Pavoni and am based in Glasgow, Scotland. I service and repair these machines all day every day and basically it could be a couple of different things. If it is pre 2000 then it could either be the piston gaskets or the piston shaft has come slightly unscrewed from the piston head. If it is post 2000 then it could be any of the above but also in these models there is an additional sleeve inside the group head which may be cracked or the seal on this part may need replacing. It could even just be a tiny bit of debris on one of the piston gaskets. If you have removed the shower plate and gasket and then taken out the piston assembley then you should really replace these gaskets anyway. You can purchase the parts on my website www.theespressoshop.co.uk which are all individually priced and every part is available for the lever machines. If you require any further assistance then please do not hesitate to get in touch at domesticespresso@live.com
All the best
Mr La Pavoni
May 14, 2010 | La Pavoni Europiccola EPC-8 Espresso...
System is not priming
This is normal after you leave the machine unused for a long time. The water dirt or scale or both make many parts to stuck like glue. The presure pump might be stuck if even if you here the noise of the vibration the outlet have been blocked. another part that can be stuck for the same reason is the water solenoid. Both can be fixed by remove them desasemble them and clean them with a wire brush. If you have a litle technician knowladge this is a very simple operation. Of course if you persist you might unsuck by trying the procedure you mention but it seems that now it is hard to be hapen.
Good Luck
Remember to vote for this answer.
Feb 28, 2010 | La Pavoni Espresso Si PAB-16 Espresso...
La Pavoni Napolitana Espresso Machine
Try to take of the top and see if you can see any thermostat fuse, on some machines this are on the boiler.
Jul 04, 2008 | La Pavoni Lusso PL-16 Espresso Machine
La Pavoni Losso Espresso machine not working.
Fill the tank with a strong De scale soulition , sounds like its blocked with limescale. REMEMBER to rinse thru clean water several times after the process...
Feb 08, 2008 | La Pavoni Lusso PL-16 Espresso Machine
La Pavoni Lusso PL-16 Espresso Machine Logo
328 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
noel
noel
guy8516
Level 1 Expert
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
