Question about Seagate (9W2041-337) 40 GB Hard Drive
Hard disk error
When i click on any disk drive it send a message
RECYCLER\S-9-50-100008139-100029216-100025713-7582.com
  • 217 Answers
You have got a virus on your system.
as a temp resolution try this
click START>RUN> type REGEDIT
click EDIT>click FIND NEXT> type MOUNTPOINTS2
and hit enter delete the key to find the next entry for this key press F3 and delete the key...keep doing until no key with this name is left
Update the antivirus software on your system and run a full scan.
As a last resort please opt for reinstallation
Note : Back up your data before that
Posted on Mar 07, 2009
Samsung r530 laptop hard disk warning
Error message when you try to install Windows Vista on computer that has...
This problem occurs because Windows Vista cannot distinguish between ambiguous hard disks.
In versions of Microsoft Windows Setup that are earlier than Windows Vista Setup, hard disks are marked with distinct values to distinguish them. However, this method of distinguishing hard disks is no longer supported because of the potential for data corruption on hard disks.
Do you have more than one hard drive connected to your computer?
If you have two hard drives, remove the second hard drive and continue with the installation.
If that does not work, try to format the C: drive while installing the Vista operating system.
You need to select the "format" option from "advanced" within Vista installation.
Click on the link below for more information.
Error message when you try to install Windows Vista on a computer that has uninitialized hard disks: "This computer's hardware may not support booting to this disk"
http://support.microsoft.com/kb/925481
Dec 02, 2014 | Samsung R530 Notebook
How can fix "send and don't send error"
Are these microsoft error messages ?
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Windows 7 chkdsk http://www.w7forums.com/use-chkdsk-check-disk-t448.html Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Optimisers and Diagnostics. http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html Improve your PC performance and fix errors.
Apr 17, 2013 | Computers & Internet
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Delayed write failed Failed to save all components for the file \\system32\\00007e87
HI...............
This error typically occurs when the "Enable write caching on the disk" feature for your hard disk is turned on.
However, if the "Enable write caching on the disk" feature is turned off, this error can occur because the Ultra Direct Memory Access (UDMA) hard disk controller may be configured in either of the following ways:
  • You are using a 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
  • The BIOS settings are configured to force faster UDMA modes.
For more information about the delayed write failure, go to the "Delayed Write Failure information" section.
To resolve this issue, first check whether the "Enable write caching on the disk" feature is turned on. If it is turned on, turn it off. To do this, follow these steps.
Note If you turn off the "Enable write caching on the disk" feature, your hard disk may perform more slowly and may affect the overall system performance of your computer. Because of this, you may want to monitor system performance after you follow the steps in this section.
To turn off Enable write caching on the disk, follow these steps:
  1. Click Start, and then click My Computer.
  2. Right-click the hard disk, and then click Properties.
  3. Click the Hardware tab.
  4. Click to select the hard disk, and then click Properties.
  5. Click the Policies tab.
  6. Click to clear the Enable write caching on the disk check box, and then click OK.
  7. Click OK to close the Local Disk (C:) Properties dialog box.
  8. Repeat steps 3 through 5 for each hard disk that is installed in your computer.
If these steps resolve the error message, you are finished.
If these steps do not resolve the error message, or if the feature is already turned off, go to the "Advanced Troubleshooting" section. This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/
Make sure that the hard disk controller is configured correctlyTo make sure that the hard disk controller is configured correctly, check the cable connection and the BIOS settings. First, try method 1.Method 1: Check that you are using an 80-wire, 40-pin cableMake sure that your UDMA hard disk controller is using an 80-wire, 40-pin cable. For information about how to do this, see the documentation that is included with your computer, or contact your UDMA hard disk controller manufacturer.
If you are using an 80-wire, 40-pin cable, go to method 2.
If you are not using this cable, obtain and use an 80-wire, 40-pin cable, and then test to determine whether this resolves the error message.
If this resolves the error message, you are finished.
GOOD LUCK................
Nov 10, 2011 | HP Computers & Internet
I have an external samsung disk and suddenly I cannot access to any of my folders. When I try opening any of them it throws an error stating that: E:/recycler/file.exe is missing. file.exe is indeed:...
Hello
Try to scan your external had disk with an updated anti virus it may possible attacked by a virus. Try to scan your hard drive using this software http://www.mediafire.com/file/do3330...aesetup2.5.zip install it and scan your PC it will automatically remove all the recycler.exe in your PC.bentech7.jpg
Jul 18, 2011 | Samsung G2 Portable External HX-MU064DC/...
Instructions For Fixing Hard Disk Errors
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Samsung.
Press Enter
If you get a message about "disk is locked - delay disk-check until next reboot", click OK, and shutdown/reboot Windows.
When "check-disk" has finished, any correctable errors will have been corrected.
Nov 13, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Recycler folder virus
You don't have a virus, you have the folders without an executeable link. Use windows explorer to delete the files you want to get rid of.
Sep 07, 2009 | Microsoft Windows XP Professional With...
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Seagate (9W2041-337) 40 GB Hard Drive Logo
80 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
