Question about Dryers
He3 dryer door wont stay shut - Dryers
  • Anonymous Apr 26, 2009
    Brand new Kenmore HE3 Dryer (purchased 3/23/09). Control Panel lights up but will not start. When you push the start button it goes "beep-beep-beep". Also, the interior light comes on. Tech says it's a problem with the door closure. A service call has been set (for 5 days from now) and I have a dryer full of wet towels!
  • 40 Answers
Their is a kit that has been made for that problem that includes the hinge and door strikers and latches. I will find the part # if you i can get the model 3 from you
Posted on Mar 07, 2009
My dryer door wont stay shut while drying
Hello Debbie;
My name is Peter. I am a retired field service appliance technician.
1.) It sounds like you have a bad door latch. These are easily replaced. With a small flat head screw driver just wedge them out.
Cost: $7.00
2.) You may also have a broken door switch. Push in on the white button to make sure it goes in. Check the contactor on the door to make sure it is not bent.
Cost: $24.00.
3.) Also, check your door seal to ensure it is not coming off from wear.
Part number 3390733 Cost: $41.00
Dec 03, 2014 | Kenmore HE3 Gas Dryer
Kenmore elite HE3 drum light always on, wont run
Ohm out the door switch if the light won't go out electronic control thinks the door is open.
Mar 31, 2014 | Dryers
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmorre HE3 turns on tumbles a few time then stops and smells like something is burning. Belts not broken. Could they still need to be replaces. Wonts start again for a few minutes
there is a thermo switch which will shut down a dryer ( its a safety feature) this may be bad. I would pull the front off and investigate to see if the motor, belt , roller etc is causing this problem. Open dryer door take out screws pry gently on each top corner and the front panel is off(some have screws in the bottom corners). Hope this helps tim
Aug 29, 2010 | Dryers
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
We are new to the Kenmore Elite HE3 8674 dryer and it won't run
Our daugther in law came over, and she forcefully shut the door, and the dryer started working. We are going to have the Sears people to come out and make certain that this dryer is not damaged.
Feb 07, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
240 people viewed this question
Top Dryers Experts
