Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Temp control flashing E 9
Just bought a kenmore standup freezer at a scratch and dent warehouse. on plugging it in, the temp. control is flashing E 9 repeatedly. it is running at a good temperature but i can't adjust it...any help would be appreciated.
  • gktada Apr 08, 2009
    Bought a 14 cu Kenmore standup scratch and dent sale. Few days later display is flashing "-10 E9". I silence the alarm and it reset. Every couple of days it pops up on display again. Freezer is still cold and nothing seems wrong with cooling circuit.
My problem seems to have gone away. I checked the wire bundle connector that goes from the door to the area under the freezer. It may have had a bad connection there. After checking the connector freezer worked fine. Only thing I had to do after was to defrost my coil. I guess in the E9 mode it skips the defrost cycle.
Posted on May 16, 2009
  • 323 Answers
Look online and see if you can find an installer's manual. Sounds like the control board hasn't been set to your model yet.
Posted on May 12, 2009
How do you defrost a older modle 13 cu ft standup freezer ?
Empty it out....pull the plug... get out the hair dryer....when all of the ice is thawed and the water soaked up then you plug it back in and restock the food...
heatman101
Jan 30, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Bought a scratch & dent freezer. Door seal is not sealing properly, lets in air. How to fix? I don't see any dents near the seal, but lots of frsot and even drips are forming. I can plainly see when...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 03, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer wont freeze beyond a chill. Please Help
Sorry to say that this happens a lot. More then likely there is a refrigerant leak and the place you bought it from had it charged right before you saw it. That is why it worked then, but not when you reached your destination.
Jul 09, 2010 | Freezers
Kenmore freezer deforsted suddenly. Comes on
compressor relay is probably going out...also check the plug in to the wall. A intermittant contact is a matter of following the source to the compressor. start at the plug and through the temp sensor/ t-stat defrost control and down to the compressor. but ususlly the compressor relay is the culprit.
Oct 25, 2009 | Freezers
Kenmore commercial standup freezer alarm
Sounds like the temp sensor is bad or intermittant. Check the connections to the display to see if they are loose. If not, the sensor might be bad, causing it to read the wrong temp. The fact that it is jumping around like that points to this kind of problem.
Oct 09, 2008 | Freezers
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Brand new freezer
FIRST TURN THE TEMP CONTRAL ALL THE WAY OFF.LISTEN FOR A CLICK AND TURN TO HALF WAY SETTING IF IT CLICK IT'S ALLRIGHT, NEVER TO COLDEST,NEXT PLUG A RADIO IN THE PLUG TO MAKE SURE YOU HAVE POWER,DOES YOUR FREEZER HAVE A LIGHT ON FRONT TO TELL IF POWER IS ON?ALSO CHECK BREAKER BOX,THANKS-MIKE
May 19, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
552 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
