I keep getting "Fill Coffee Bin" when the bin is
Sounds like the grinder is blocked. Set the grinder to the coarsest setting (largest number) and try a few more times. If still no luck then vacuum out all the beans, run the grinder again a couple of times and then add a small amount of fresh beans (not from a fridge or freezer as these will be moist and can cause problems) and try making coffee again. If after a few tries it still doesn't work then you will either have to remove the top grinder burr and clean both burrs (not recommended unless you are bit of a handy person) or you could try vacuuming out the beans again and letting the grinder dry out for a while (although unlikely, it could be wet from water spillage). Good luck hope this helps.
