Question about Alpine Car Audio & Video
ALpine 7235 needs wiring diagram.
This unit has a 28 pin connector in the rear.
please send any info regarding hooking this up.
thanks
JMuskovitz
  • 135 Answers
SOURCE: JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
Inferno77
  • 6 Answers
SOURCE: Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Posted on Jul 27, 2007
Ryan5443
  • 336 Answers
SOURCE: spdif pins
First of all when you got these pictures were they from *********** board?If they were did you wear a wrist bracelet to prevent Electro Static Discharge (ESD)? If not you may have just ruined your computer. But there is a chance you didn't. Next I am not positive but you might need to get a three pin SPDIF connector from Radio Shack. But I would try the one you have. See if it works. But I must warn you going inside your computer if you are not a technician can be very harmful to your computer. So if you take my advice Touch some part of metal on the outside edge so you are grounded to your computer.
P.S. Damage from ESD may not be right away. It can be months from when the computer was shocked. If my advice doesn't work tell me and i will give you much more help.
Hope this Helps.
RCF
Posted on May 27, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
I have an SDI Spirolab II Spirometer. The connector for the mouthpiece has broken wires. I need wiring info regarding which color wire goes on which pin.
It is very difficult to get the wiring diagram. Recently it has become very difficult to get information about internals of electronic gadgets. Because everything is proprietary now. You should contact the manufacturer for the wiring diagram.
Feb 21, 2011 | Health & Beauty
Missing power supply. First, thanks to fredtmccoyjr for the boot fix. the BIOS update from A06 to A09 actually allows me to enable boot from harddisk in the settings, instead of settign a useless tick on...
It was the 1996 to 2000 time frame, that Dell was proprietary with the 20-pin ATX main power cable, and the matching connector on the mobo. (MOtherBOard).
Standard 20-pin ATX main power cable, and it's corresponding connector should work, then add the 4 power wires that are missing, in a separate connector.
To expound:
View this standard 20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
The power wires should be in the same place as your P3 units.
(Match the color codes.
Use the lock tab on the 20-pin ATX main power cable connector, to base where the pins are.
Pins 1 though 20. Match the color code of the wires to the pins, and use the chart to compare)
Here is a view of a standard 24-pin ATX main power cable, and it's respective connector, so you can see what power wires are missing, from the 20-pin ATX main power cable connector, that are present in the 24-pin ATX main power cable connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the missing power wires, and what pins they line up with.
The P4, or also stated as the 4-pin ATX +12 Volt power cable, uses two Yellow (12 Volt) wires, and two Black wires, (Ground)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Since you don't have the male connector, be sure to orient in your mind where the Yellow (12 Volt) wires go, and the Black (Ground) wires go, by looking at the lock tab on the side of the female connector, on the motherboard, and comparing it to the photo.
Transfer this info, to the P4 connector you are going to make.
Where to get the power wires you need? Connect to any extra 4-pin Peripheral power cable wires, or splice off of ones that are in use, is one suggestion.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The links given are near the middle of the page. Scroll back to the top. Left-click on any power cable connector, that you wish more information on.
More info,
http://en.wikipedia.org/wiki/Computer_power_supply
Scroll to the bottom of the page, and look at the chart under the heading -
24-pin ATX12V 2.x power supply connector
(20-pin omits the last four: 11, 12, 23, and 24)
One more link,
http://www.smpspowersupply.com/connectors-pinouts.html
Lastly Dell Support > Optiplex GX260 > Service Manual,
http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htm
Just in case it's of any use.
Have questions regarding what I have stated, or need more clarification of anything I have stated, simply post in a Comment.
Jul 06, 2010 | Dell OptiPlex GX260 PC Desktop
I need the pin cinfig, for the front pannel
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 01, 2009 | MSI MS-6580 Motherboard
Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Feb 21, 2009 | Alpine CDA-7940
Monitor will not show dvd
you need to put the dvds handbrake wire to a suitable earth point and then your dvds will play fine i think the wirings colour is a yellow with a blue tracer line on the wire if its an alpine dvd player and the same is on all the monitors themselves that wire will have to be connected to a good earthing point but luckily on the monitors they have a black earth wire running to them so just splice that yellow/blue wre into the black earth wire on each headrest monitor !
Feb 13, 2008 | Alpine TME-M770 6.5 in. Car Monitor
PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Nov 03, 2007 | Alpine CDM-7833
Wiring on tape deck Alpine tdm-7543
hi there is a manual in the model page click on it page 2 there is a description how to connect the unit good luck
Mar 20, 2006 | Alpine TDM-7543
Car Audio & Video Logo
65 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
