Question about Renault Dauphinoise PTT French Post/Telephone Van
Need tool for changing oil on renault kangoo - Renault Dauphinoise PTT French Post/Telephone Van
    Sergeant:
  • 184 Answers
You req a sump plug tool for this job basically its a square plug you can by these tools in motoring shops or on ebay don't cost that much if your in uk you can buy them in halfords.
Posted on Mar 07, 2009
How do i get air box of my kangoo 98.so that i can replace rocer cover gasket
Posted on Feb 13, 2010
3 Suggested Answers
SOURCE: FITTING A OIL FILTER FOR A RENAULT KANGOO
If its a kangoo 1.6 the oil filter is between the engine and the radiator at the front of the engine on the left hand side (from the front of the car) and is acessable from below.
Posted on Nov 27, 2009
philbatten1
SOURCE: what tool do i need to change oil in my kangoo
You probably need a 11mm square Drain Plug Key.
Posted on May 27, 2010
I have a 2002 Renault Kangoo van 665d 1.9 diesel. Where is the oil cooler located and what does it look like?
If you find your oil filter, you fill find the oil cooler. It is the little box that the oil filter screws into. You will see two coolant hoses going to it as well.
Nov 09, 2017 | Renault Cars & Trucks
How to change a auxiliary belt without using a auto tensioner on renault kangoo 1.9 diesel cars
you have to have serpentine belt tool kit. and do not have to buy one unless you want one, most auto parts have loaner tools you have to have a credit card to secure the cost of replace in case you loose a part or you do not return it, then they charge your credit.
you need that tool to release the tension on the belt, it is not possible to not do without that tool, i tried doing that i tried for 5-6 hours without any luck. i went down to auto store got the tool and we got done in 15 minutes.
take it from me it not worth all that waist of time and energy just get the tool. its fast and simple.
thank you rod
Mar 03, 2015 | 2005 Renault Kangoo RX4
Where can i find the transmission type for a Kangoo 1.4 automatic
Renault Kangoo (KC) 1.4 i car data and specifications. Renault Kangoo (KC) 1.4 i car information and specs Bodywork Bodywork type Minivan Length (mm) 3995 Height (mm) 1827 Width (mm) 1663 Number of seats 5 Number of doors 4 Wheelbase (mm) 2600 Track rear (mm) 1418 Track front (mm) 1405 Ground clearance (mm) 140 Total (curb) weight (kg) 1155 Gross (max.) weight (kg) 1665 Max. cargo capacity (volume) 2600 Min. cargo capacity (volume) 650 Tires 165/70 R14 T Engine Engine displacement (cm3) 1390 Engine location Front, transverse Cylinder type In-line Bore (mm) 75.8 Number of cylinders 4 Compression ratio 9.5 Stroke (mm) 77 Valves per cylinder 2 Turbo - Fuel supply Distributed injection Engine power (hp) 75/5500 Engine torque 114/4250 Transmission Wheel drive Front Number of gears (automatic transmission) 4 Steering Type of steering Wheel-rail Power steering Hydraulic system Brakes Brakes rear Drum brakes Brakes front Ventilated disc brakes ABS + Performance Acceleration to 100 km/h 17.3 Fuel capacity (l) 50 Fuel consumption - city (l) 9.5 Fuel consumption - road (l) 6.3 Top (maximal) speed (km/h) 147
Renault Kangoo (KC) 1.4 i car bodywork specifications: Renault Kangoo is a minivan with 5 seats and has 4 doors. Dimensions information of car: 3995 mm long, 1827 mm high, 1663 mm wide. Other Renault Kangoo (KC) 1.4 i cars specs: 2600 mm wheelbase, rear track has 1418 mm, front track has 1405 mm, ground clearance - 140 mm. Total car weight is 1155 kg and 1665 kg of maximum weight, cargo capacity (volume) if from 650 to 2600. Tires type for Renault Kangoo (KC) 1.4 i is 165/70 R14 T. Car engine specifications: 1390 cm3 displacement, located front, transverse with in-line cylinders, 75.8 mm bore. Renault Kangoo (KC) 1.4 i has 4 cylinders. More car engine information: 9.5 compression ratio, 77 mm stroke, car has 2 valves per cylinder, distributed injection fuel supply type, engine power 75/5500 hp, engine torque equals 114/4250.
Transmission specifications of Renault Kangoo (KC) 1.4 i wheel drive is front, it has 4 gears of automatic transmission,.
Renault Kangoo (KC) 1.4 i has wheel-rail type of steering. And hydraulic system power steering.
Rear brakes are drum brakes. Front brakes specs: ventilated disc brakes.
Performance Renault Kangoo car data: it takes 17.3 sec. for Renault Kangoo (KC) 1.4 i to get 100 km/h speed. 147 km/h is the max speed. Renault Kangoo gasoline tank has 50 liters capacity. The car consumps 9.5 liters in the city, 6.3 liters on the road.
TMTM
Jun 28, 2014 | 2003 Renault Kangoo
Renault kangoo fuse box diagrams
On this website (link below) you finde fuse box diagram for Renault Kangoo
Renault Kangoo mk1 1996 2006 fuse box diagram Auto Genius
Dec 30, 2013 | Renault Cars & Trucks
Had a new turbo fitting last week only got the van back seems to be a tapping noise coming from the engine stops some times when i change gear . some 1 said injectors or tapits havent a clue the van is a...
Did they also change oil to a heavier weight? Turbos are oil cooled and require heavier oil to extrude heat. Check with folks who did turn install and if they didn't I think an oil change is needed.
Mar 03, 2011 | Renault 181 Cars & Trucks
What tool do i need to change oil in my kangoo
Ok this is a late post I knoe only just bought a kangoo 1.5 dci, I like to think I have good tool kit sees me through just about any job, except this one, undoing an oil drain plug.....AW man what a pain ...............something.
Two britool tool kits and no joy. I swear I think the french are paying us back for donald rumsfeld's cheese eating surrender monkey jibe....I mean why not just a bolt nice and easy...so the engine flush is in the oil, I am far from a parts company, no driving the car now then..So its the old case of nessescity being the mother of all invention. I like most of you searched goolgle in hope of an answer and nothing..Until I remembered an old door lock I had on the top shelf and after hours of getting nowhere, it turns out that the spindle that goes between the handles of a door was pure goldielocks(UK anywayFrench probably got there own sizes) Its worth mentioning I did need to soak the sump drain plg with Wd40 qite afew times. PS the door spindles is 8mm2
If you dont have the proper tool I hope yo see this before you start
AW
Mar 07, 2009 | Renault Dauphinoise PTT French...
Nov 24, 2008 | Renault Dauphinoise PTT French...
Renault Dauphinoise PTT French Post/Telephone Van Logo
1,611 people viewed this question
Top Renault Toys Experts
xxxxxx xxx
Travis cook
Are you a Renault Toy Expert? Answer questions, earn points and help others
