Question about Renault Dauphinoise PTT French Post/Telephone Van
What tool do i need to change oil in my kangoo
Hello i am trying to change the oil on my renault kangoo, But when i try to undo the bolt nothing seams to fit it.
Can anyone please advise me were i can get a tool that fits the bolt.
if you also know how much the tool will cost and were i could get it i would be very gratefull.
Thank you
Ok this is a late post I knoe only just bought a kangoo 1.5 dci, I like to think I have good tool kit sees me through just about any job, except this one, undoing an oil drain plug.....AW man what a pain ...............something.
Two britool tool kits and no joy. I swear I think the french are paying us back for donald rumsfeld's cheese eating surrender monkey jibe....I mean why not just a bolt nice and easy...so the engine flush is in the oil, I am far from a parts company, no driving the car now then..So its the old case of nessescity being the mother of all invention. I like most of you searched goolgle in hope of an answer and nothing..Until I remembered an old door lock I had on the top shelf and after hours of getting nowhere, it turns out that the spindle that goes between the handles of a door was pure goldielocks(UK anywayFrench probably got there own sizes) Its worth mentioning I did need to soak the sump drain plg with Wd40 qite afew times. PS the door spindles is 8mm2
If you dont have the proper tool I hope yo see this before you start
AW
Posted on Jul 10, 2012
You probably need a 11mm square Drain Plug Key.
Posted on May 27, 2010
Its a square headed nut you can bye the tool in halfords or on ebay
Posted on Nov 27, 2009
I need,help on my renault kangoo 1.4 I buy new head bolts but there are short one and long ones where come witch bolt please
You can find many websites selling Renault parts. Here you have some but if you do a simple search for Renault parts, you'll get more.
Now, honestly, I have no idea if your Reault Kangoo 1.4 uses short or long bolts. Maybe contacting any of those sites carrying Renault parts can help you
Oct 25, 2015 | Renault Cars & Trucks
How to change a auxiliary belt without using a auto tensioner on renault kangoo 1.9 diesel cars
you have to have serpentine belt tool kit. and do not have to buy one unless you want one, most auto parts have loaner tools you have to have a credit card to secure the cost of replace in case you loose a part or you do not return it, then they charge your credit.
you need that tool to release the tension on the belt, it is not possible to not do without that tool, i tried doing that i tried for 5-6 hours without any luck. i went down to auto store got the tool and we got done in 15 minutes.
take it from me it not worth all that waist of time and energy just get the tool. its fast and simple.
thank you rod
Mar 03, 2015 | 2005 Renault Kangoo RX4
Where can i find the transmission type for a Kangoo 1.4 automatic
Renault Kangoo (KC) 1.4 i car data and specifications. Renault Kangoo (KC) 1.4 i car information and specs Bodywork Bodywork type Minivan Length (mm) 3995 Height (mm) 1827 Width (mm) 1663 Number of seats 5 Number of doors 4 Wheelbase (mm) 2600 Track rear (mm) 1418 Track front (mm) 1405 Ground clearance (mm) 140 Total (curb) weight (kg) 1155 Gross (max.) weight (kg) 1665 Max. cargo capacity (volume) 2600 Min. cargo capacity (volume) 650 Tires 165/70 R14 T Engine Engine displacement (cm3) 1390 Engine location Front, transverse Cylinder type In-line Bore (mm) 75.8 Number of cylinders 4 Compression ratio 9.5 Stroke (mm) 77 Valves per cylinder 2 Turbo - Fuel supply Distributed injection Engine power (hp) 75/5500 Engine torque 114/4250 Transmission Wheel drive Front Number of gears (automatic transmission) 4 Steering Type of steering Wheel-rail Power steering Hydraulic system Brakes Brakes rear Drum brakes Brakes front Ventilated disc brakes ABS + Performance Acceleration to 100 km/h 17.3 Fuel capacity (l) 50 Fuel consumption - city (l) 9.5 Fuel consumption - road (l) 6.3 Top (maximal) speed (km/h) 147
Renault Kangoo (KC) 1.4 i car bodywork specifications: Renault Kangoo is a minivan with 5 seats and has 4 doors. Dimensions information of car: 3995 mm long, 1827 mm high, 1663 mm wide. Other Renault Kangoo (KC) 1.4 i cars specs: 2600 mm wheelbase, rear track has 1418 mm, front track has 1405 mm, ground clearance - 140 mm. Total car weight is 1155 kg and 1665 kg of maximum weight, cargo capacity (volume) if from 650 to 2600. Tires type for Renault Kangoo (KC) 1.4 i is 165/70 R14 T. Car engine specifications: 1390 cm3 displacement, located front, transverse with in-line cylinders, 75.8 mm bore. Renault Kangoo (KC) 1.4 i has 4 cylinders. More car engine information: 9.5 compression ratio, 77 mm stroke, car has 2 valves per cylinder, distributed injection fuel supply type, engine power 75/5500 hp, engine torque equals 114/4250.
Transmission specifications of Renault Kangoo (KC) 1.4 i wheel drive is front, it has 4 gears of automatic transmission,.
Renault Kangoo (KC) 1.4 i has wheel-rail type of steering. And hydraulic system power steering.
Rear brakes are drum brakes. Front brakes specs: ventilated disc brakes.
Performance Renault Kangoo car data: it takes 17.3 sec. for Renault Kangoo (KC) 1.4 i to get 100 km/h speed. 147 km/h is the max speed. Renault Kangoo gasoline tank has 50 liters capacity. The car consumps 9.5 liters in the city, 6.3 liters on the road.
TMTM
Jun 28, 2014 | 2003 Renault Kangoo
Default code for cd player in renault kangoo
can anyone help, I need the Cod for my CD radio for the Kangoo Year 2003
CD-Radio-Player Renault:
MODEL NO: 22 DC 279/62
PROD NO: FDO 503 120 208 915 oder 7700 4339 48 TJ 568
Thank you very much
Jun 21, 2012 | Audio Players & Recorders
Torque setting cylinder head bolt renault kangoo 1.4
my alldat book says 20nm and then 240? with new bolts,what a load of rubbish ,clean the bolt holes out and make sure no water or oil down them ,do in sequence and tight first pass with a rachet then a big bar or in your case the torque wrench and around 65lbs for a petrol will suffice
Sep 02, 2011 | Renault R5 Cars & Trucks
Need tool for changing oil on renault kangoo
you req a sump plug tool for this job basically its a square plug you can by these tools in motoring shops or on ebay don't cost that much if your in uk you can buy them in halfords.
Mar 07, 2009 | Renault Dauphinoise PTT French...
Head bolt rounded off on magene 2lts edi its 2001
if you can access the bolt with a dremel tool, you can grind new flats in the sides and try a slightly smaller six pointed socket. If you have an arc welder, you can weld another good bolt to the top of the rounded off bolt head and use the head of the good bolt to undo it.
Jan 07, 2009 | 1986 Renault Sport
FITTING A OIL FILTER FOR A RENAULT KANGOO
If its a kangoo 1.6 the oil filter is between the engine and the radiator at the front of the engine on the left hand side (from the front of the car) and is acessable from below.
Nov 24, 2008 | Renault Dauphinoise PTT French...
Renault Dauphinoise PTT French Post/Telephone Van Logo
861 people viewed this question
Top Renault Toys Experts
xxxxxx xxx
Travis cook
Are you a Renault Toy Expert? Answer questions, earn points and help others
