Question about Dell Computers & Internet
My dvd rw can not open some of the dvd and dont khnow how do i fix this problem. please guide me.
    President:
  • 1,223 Answers
Due to dust and excessive use it happens the lens gets dusty or weak solution is
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works , other wise ur DVD drive lens got weak from use now a days service centers are getting tons of them everyday for replacements
pls do rate me FIXYA if i fixed what u wanted
Posted on Mar 07, 2009
Need to replace dvd player in Toshiba Satellite C655
http://www.youtube.com/watch?v=ChrYyWjaEMY Toshiba Satellite C650 L675 DVD Replacement Guide Installation -- L670 C655. Install Fix Replace CD DVD/RW Optical Drive Burner. This guide is useful for these laptop models: TS-L633 - 142, V000210060, C655D, C650D, L675D, L670D
Jan 30, 2013 | Toshiba Satellite A135 Notebook
My DVD RW won't read anything. The little disk image appears but I never hear it spin up. When I click on the icon on my computer, a window comes up that says to insert disk even though a disk is already...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
hope this helps
dont forget to vote
Feb 12, 2011 | Gateway (5500381) CD-ROM Drive
How do i replace dell optiplex 760 cd-rw/dvd
Here is the link to the service manual for your computer, since we do not know what formfactor the case is, go to the link, pick your case form and look through the manual for case opening instructions. Be sure to save a copy of the manual for yourself for a refernce.
http://support.dell.com/support/edocs/systems/op760/en/sm/index.htm
Oct 14, 2009 | Computers & Internet
Pioneer dvd rw dvr-k16a driver of toshiba laptop not functioning
this shows that your DVD RW is out of order and the only solution is to replace it with the new one.
dont forget to vote
Oct 10, 2009 | Pioneer DVR-K16 Burner
Non-opening dvd/rw
Well, it may have got jammed. so try this trick.....
If you look at the dvd/rw drive..on the side of the button of the drive...you will find a very tiny hole so take a paper pin and insert it in the tiny hole if the drive is opened great!!! otherwise get it replaced as the dvd/rw drives are not costly thesedays..
Sep 08, 2009 | Pioneer DVR-107D DVD±RW Burner
DVD_RW ND-3550A 5XIFA95S211
HELLO THERE
here is a link that will help you out ok?
pease dont forget to give this solution a rating i really need it.
best regards mike
  1. Asus Cd-Rw & DVD-Rw Drivers You can download Asus Cd-Rw & DVD-Rw Drivers for your hardware. If you want to use Asus Cd-Rw & DVD-Rw Drivers for other purpose, Please contact ...
    www.updrivers.com/drivers/Cd-Rw_DVD-Rw/Asus/3/58.html - 9k - Cached
Aug 21, 2009 | ASUS Computers & Internet
Certain DVD disc can able to openSONY DVD RW DRU-810A, But I am unable to open with SONY DVD RW DW G521A. Kindly advise me to further course of action.
yes, most of the dvd recorders are like that. you must read the user guide to find the correct dvd brand to use. i have a toshiba (i can only use maxell, (best) tdk ,dynex (good) and memorex (Ok)) fuji sony pansonic will not record nor play.
http://www.supermediastore.com/dvdmedia.html blank dvds for sale
May 06, 2009 | Televison & Video
I want to burn dvd using cheetah dvd burner,when i press burn a note says''insert a media writable
Might be several reasons
Take a look on front panel if it says DVD-RW use only DVD-R (RW) blanks, +RW only +R(RW), +/- or RAM both. Check the record speed your blanks might have higher speed than allowed
Also blank might be upside down
Hope that helps
Good Luck
Mar 05, 2009 | Compaq Computers & Internet
Poineer dvd rw for computer codecs
What program are you using for the payback, what operating system are you using? as this help with the fix.
May 11, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Lg dvd writer
First try to clean the drive (dvd drive cleaner cd).
If the problem continues then replace the drive with new one.
May 06, 2008 | LG Electronics GSA-H42LK LightScribe 18X...
Computers & Internet Logo
67 people viewed this question
Alun Cox
