Question about JVC RX-9010V Receiver
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
When unit turns on it always shows headphone and auto muting on the display but when I tune the receiver to an fm station I get not sound, is it trash or worth repairing as I only paid $10 for it???
    New Friend:
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Posted on May 18, 2013
SOURCE:
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Posted on Mar 26, 2009
SOURCE: I have a J JVC RX-558V. The mute light is always on so it does not play sound. I can't find the key sequence on the front of the unit to disable Mute?
Posted on Aug 17, 2009
seagreg
SOURCE: JVC receiver shows power, but won't turn on
Fujitsu,
The above describes my same issue w/ my JVC RX-9010 receiver.
How do you determine if a transistor is bad? What equipment besides an analog multimeter would I need? I am out of work so replacing this is not an option. I can solder as well so if I can ID the transistor I gather I can repair this cheaply? Many Thanks!
Posted on May 12, 2010
Trying to get new headphones to cancel speakers on tv
What kind of headphones and TV are you trying to make work as an combined pair? It sounds to me as though you have your head phones plugged into the speaker location on the TV which could be a small hole that shows a pic of speakers. Look on the TV for an 'mic' or 'pic of headphones' holes. If there is an plug in hole with either it states mic or shows a pic of headphones plug the headphones into that hole instead of where you have them plugged into now.
Another suggestion is to use MDI cords in which you may already be using aka white, red, yellow colored plugs. If those plugs are assembled in the slots incorrect that also could be the reason as to why the headphones turn down when you turn the volume to the TV down; which also would influence the TV volume its self to also disengage to go either louder or quieter. MDI cords should be plugged in the following pattern to be categorized as the following with each color following the next color; yellow, white, red. Now if you are using MDI cords presently do you have them plugged in front or back of the TV?
If the TV has hole ports in both front and back for MDI cords then reverse your plug ins. Example: If you have them plugged in the front instead switch all three to the back of the TV or vise versa.
Also another thing; since you are wanting to use headphones for your TV speakers instead of the TV speakers themselves usually plugging headphones in are controlled by TV volume buttons; however I am assuming that you are trying to state that when you plug headphones into the TV you still hear the volume in your ears and anyone in the TV room is also still hearing the TV even though headphones are plugged in, am I right?
With you wanting to cancel the speakers on the TV out only attempted to use TV volume for speakers and without it working means you have the MDI cord plugged into the audio which would cause the TV to power the volume for the headphones anyways. May I ask this; since I am a bit confused, alright are you wishing for the headphones to be able to be loud enough so the TV only powers them for volume when you use the TV?
I know that headphones being plugged into an TV should only keep their volume within the ear buds. Therefore I have never heard of headphones being able to be loud enough to power out room sound. Instead they power internal volume which would be within your ears. Headphones were meant to keep noise and volume from surrounding a room to block room noise out and to keep the sound for your/ an own persons only listening capability. So because of this I am confused as to how ear phones would have the ability to sound the room with audio.
I can understand that if what you are trying to say is that the speakers on the TV still output volume even with head phones plugged in which would be an issue, since head phones are to capture the volume and noise from the unit in which plays aloud- to actually silence it instead- for the individual whom requires or presumes to have themselves to be the only listener.
Jan 02, 2014 | JVC 900MHz Wireless Stereo Headphones with...
The sound has stopped working on our GeoSafari LAPTOP No. 8545. Help!
Hi Lisa,
What operating system are you using?
Check that sound is enabled in both the operating system and BIOS.
Check that you have the volume turned up.
If you have an external set of speakers, try plugging them in and see if you get sound. If the external speakers use a power supply, make sure you have the speakers powered and turned on. Computer speakers almost always require power to run the internal amplifier. Computers sound output is so low that regular speakers can not be used. Also, if you have a set of headphones from an iPod or similar device try the headphones. Headphones are sensitive enough to work without power.
Aug 06, 2012 | Computers & Internet
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
Have JVC 6008V A/V Receiver. No out-put from left-front speaker out terminals. Checked fuses, and all are good. R/F, and all other speaker out functions work fine.Switched speakers to make sure problem was...
make sure you're using the corresponding speaker inputs for speaker 1 (only) and turn off Speaker 2 on the bottom left corner near the headphone jack (it should be sticking out further then the speaker 1 button). hope this helps.
Aug 06, 2010 | JVC RX-6008V Receiver
No sound from creative t3030 2.1 speakers
you checked adapter light the green light is show
Jul 23, 2009 | Creative Labs Inspire T3030 Computer...
No sound from speakers.
Hi...
On some stereo gear the headphone jack interrupts the speaker connection when the headphones are in. you "might" have something broken in the headphone jack which is keeping the speakers from turning on.
Is there a MUTE switch on the unit?
Or an "External speaker off" thingy in the menu?
Sep 07, 2008 | JVC TH-M303 System
Subwoofer not working
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=30&modelId=MODL027222
cut n paste the link for the manual
Are headphones plugged into it?
Is the headphone jack damaged?
Are there speaker fuses on this model? If so, check them.
Dec 06, 2007 | JVC TH-M505 System
Sound from one speaker but not the other
may be power ic one channel failed
Mar 29, 2007 | JVC TH-M505 System
JVC RX-9010V Receiver Logo
253 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
