Question about Logitech Squeezebox Duet
Hi i need a replacment battery for my squeezebox duet controller
logitech squeezebox duet controller
have found its a sanyo part
discriptin is
Li-ion Recharble battery
1250mAh 3.7v 190582-0000 l-lu18
sn f1240058 l/n l49b
can any body help
  • Anonymous Apr 11, 2009
    need battery
  • 45 Answers
Hi there, you can get this logitech remote control battery at batterytrader.com here
http://www.batterytrader.com/logitech-harmony-1905820000-remote-control-battery-p-7496.html
Posted on Jul 11, 2009
Replace squeezebox boom battery
The battery for the Remote Control? That's the only battery a Squeezebox Boom has.
  1. Remove the back cover
  2. Replace batteries.
  3. Put back cover back on.
Download Logitech Squeezebox Boom Manual
Jan 24, 2014 | Logitech Squeezebox Boom Radio
My squeezebox duet controller's screen is blank Could this happen if the battery is dead? We were away for a week on vacation. The controller was/is in the charger. When we came back, the screen was...
Hi King,
Yes this totally could be the issue, but it should still work on his base. In any case, contact logitech support for this issue, you ll get a replacement of the defective part if still under warranty Have a great day !
J -
Jul 31, 2010 | Logitech Squeezebox Duet
Compatibity with Logitech Squeezebox touch
Hi, The squeezebox is fully compatible with your system, you can connected them together thru: RCA, Minijack, COAX/TOSLINK Thanks and have a nice day ! J -
May 14, 2010 | Bose Companion 5 Multimedia Speaker System...
Mar 25, 2010 | Bose Companion 5 Multimedia Speaker System...
Squeezebox duet drops out
Hi, Did you try by Ethernet connection ? Does the problem reproduce ? If not the you might be too far away from the access point, Do you have any bandwith consuming application running on your network ? Does the problem happen with webradio and your tunes ? Thanks and have a great day J -
Dec 30, 2009 | Logitech Squeezebox Duet
Trying to hook up logitech squeezebox
Hi. Slimserver is not supported anymore by Squeezebox systems, now you must download and install Squeezebox server 7.5.0 http://downloads.slimdevices.com/ This way it will install and works without problem. Thanks and have a nice day J-
Oct 17, 2009 | Logitech Squeezebox Duet
I need to connnect a logitech squeezebox to an amplifier. Not sure which inputs to plug into?
Hi, You can use Optical/Coax or RCA or JACK to connect your squeezebox to an amplifier. Thanks and have a nice day J-
Sep 26, 2009 | Logitech Squeezebox Duet
No audio coming from logitech squeezebox duet
Did you try with the different connection method at the back of the receiver?
Are you talking about the remote jack ? This is normal, it still is a beta feature. Thanks to be a bit more specific if possible, Have a great day J-
Jun 03, 2009 | Logitech Squeezebox Duet
Remote doesn't recognize squeezebox duet
I have experienced the same connectivity issues with the Duet system. My first system was sent back for a replacement within the 30 day return policy. The second unit worked considerably better but the remote controller would still sometimes completely lose the link with the Squeezebox receiver after being left in the charger for an hour or two (or just set aside a while). Firmware upgrades seemed to slightly improve the situation, but I eventually sent the controller back for a replacement. The tech rep said they've had issues with the controllers. When I asked if I needed to return the receiver as well, he said "It's the controller, we've seen the problem quite a bit."
So, it seems the wifi function on the hardware can sometimes be defective. Update the firmware on everything, and if you've still got problems, insist on a replacement unit (it will likely be a refurb).
Good luck.
Jan 09, 2009 | Logitech Squeezebox Duet
Logitech Squeezebox Duet Logo
2,084 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
