Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
My Bialetti mukka expresso maker won t pus...
By amieinfl on Mar 07, 2009
my Bialetti mukka expresso maker won t push coffee into the top chamber the pressure valve pops up but the coffee doesn't come out.
Best Solution
posted on Apr 23, 2009
Very Helpful)
sinify
Rank: Apprentice
Rating: 100%, 1 votes
hey, it might be congested - this happens sometimes when coffee grounds get stuck in any part after a while - take the whole thing apart, including the gasket and filter and scrub everything out, then do a water run (no coffee) just to clear the thing up.
The problem might also be with coffee ground stuck in the pressure valve nozzle. Run water through it to see if it spurts out to check if there's any obstruction.
To get rid of the stuck ground in the nozzle, i once used a piece of dental floss twisted to reach within the nozzle.
hope this works for you!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
How do I remove the steam knob from my saeco vienna expresso maker. We have to fix it
Answer
my bunn thermofresh coffee pot will no longer keep the coffee hot. I always put hot water in the pot... (More)
Answer
Help! Someone tried to make hot chocolate in my Melitta coffee urn. Now it will heat but will not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
