Question about Amana DLE330RAW Electric Dryer
I purchased an Amana drier a few years ago and my aunt purchased the exact drier the model #ALE331RAW It heats so hot you can not hardly touch the cloths
    President:
  • Amana Master
  • 2,651 Answers
Too hot??? thas gerenally a sign of insuffecient venting, check for arestricted and/or blocked vent. it cant release the proper amount of heat and its buildingup inhte machine
Posted on Mar 15, 2009
I have an Amana Refrigerator Model ARS2666AW. The refrigerator temp is running at 38 to 40 degrees, but the freezer will only go down to 26 to 27 degrees.
your ref possible short cycling operation check your condenser fan of woking . check the refrigerant charge if ok if not need for recharging try to adjust the setting of thermostat. check filter drier maybe clog up if drier cold when u touch this means clog up if warm means ok if condenser not hot it means possible leak of refrigerant.
Feb 19, 2011 | Refrigerators
I have Amana Electric dryer model #ALE331RAW. IT HEATS AND TUMBLES BUT IT DOESN'T GET THE CLOTHES DRY, COULD IT BE THE BLOWER FAN AND HOW TO REPAIR?
first, make sure all your seals are in place, like door and drum. if they are ok then disconnect the vent pipe on back and try to dry a load. if it does then you have a blockage at the venting.
Feb 09, 2011 | Dryers
My dryer heats up but I have to restart the cycle to get clothes dried all the way Amana LEA80W
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Oct 18, 2010 | Amana ALE331RAW Gas Dryer
How do you adjust a slipping belt for an Amana # ale331raw? Thanks
The belt ribs go against the drum. This link shows various configurations BELT CONFIG.
Your dryer tech service manaual: AMANA DRYER
Oct 13, 2010 | Amana ALE331RAW Gas Dryer
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Amana LD10 1000 Watts Microwave Oven
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
My AMANA electric drier will not heat
Verify 220 volts to the terminal block where the cord connects.
If 220 is there, unplug the dryer and check the thermal fuse and hi-limit thermostats on the dryer cannister.
Feb 22, 2009 | Amana NDE2335AY Electric Dryer
Thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
Amana DLE330RAW Electric Dryer Logo
141 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
