Question about Fujitsu LifeBook S4510 Notebook
Audio driver does not work
Hello, I just got an old fujitsu s4510 and get the yellow triangle over the "Intel AC97 audio controller" I don't seem to find the driver anywhere in the web. Coud you give me a hand please? Thanks.
  • ticonatural Mar 07, 2009
    I think the motherboard is Intel® 82440MX. Is that possible?
  • ticonatural Mar 16, 2009
    Thanks a lot for your answer, it really helped.
  • 565 Answers
Http://webdownload.fujitsu-siemens.com/download/FileDownload/fileDownload.aspx?SoftwareGUID=E0F26D05-EC92-4706-BCEF-2E0FBF613E6B&FileFolder=Downloadfiles&FileTypeExtension=ZIP&FileNameClient=FSC_SoundSigmaTelAC97Audio_512017117_1002446.ZIP&FileSize=79071&From=UXJwY19rRGdqY1JtQHBtdXFjcCIk
if helped rate fixya
Posted on Mar 07, 2009
Where can I download the audio drivers? WinXP Pro SP3
Ouch XP!! It is possible, probable that the drivers cannot be obtained any more for that software. You could try and see if the computer can find any by clicking on check for updates on the relevant bit that comes up, control panel, then the Device manager, then open program and then go down to audio, click on that and then look for drivers. However I suspect that they are obsolete!
Sep 03, 2014 | IBM NetVista PC Desktop
Audio not working
Hello here is the homepage:
http://www.asus.com/Motherboards/AMD_AM2Plus/M4A785M/#download
Please select your windows system 32 or 64 bit.
Try install the newest sounddriver from the site.
Try downloading a manual.
Check the bios setting for plug and play Os must be set on.
And the settings for the audio try the ac 97 setting not the hd audio
Check also the connection for the audio front panel.
Some audio front panel does not support HD audio only ac97.
Look also in the device manager for fault (yellow triangle)
Good luck
Nov 25, 2012 | ASUS M4A785M Motherboard
I need audio driver for Prescott 533 mother board.
Your board has Realtek ALC655 with AC97 codec. This is realteks site;
http://www.realtek.com.tw/downloads/
I don't know what version of windows you are running but Windows 7 has had some compatabilty problems with older software. What are you using for video on this system? If you're using Radeon HD, you may be able to gain sound through there. Anyway, with Windows 7 tou may want to try a generic driver provide by windows or, you may want to try to let Intel scan your system here;
http://downloadcenter.intel.com/
If you go to "device manager", click on box, on right, of "sound audio and game controllers" do you see any warnings, !, ?, or yellow triangle?. If so click on the symboland follow proceedure. Right click on your devices(s), one at a time and, in the kist you should see "disable". If you see "enable" click on that and exit. Right click on you device(s) again, then on the "properties" tab. You should see "this device is working properly". Click on the "driver" tab", then on "update". Click on "search automatically for update...", and exit when finished. You should have a speaker icon in your task bar, lower right of screen, right click on that, then on open sound mixer, and adjust your volume.
May 10, 2011 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Plz submit the Intel d845 gvsr sound driver
go to :
http://www.download3k.com/System-Utilities/System-Maintenance/Download-Realtek-AC-97-Drivers.html
and download
Jan 10, 2011 | Intel D845GVSR Motherboard
I need intel 865 motherboard audio driver
if your computer came with a motherboard disk the drivers could be on it
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 20, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hello, i have Intel motherboard D101GGC. My sound card is not working. the motherboard has inbuilt sound chip. but it does not seem to accept any drivers.. or detect any drivers compatible with it. I...
Try another (known to work) soud spreakers. (Still no sound)?
Enter the bios/cmos menu & check audio setting.
Make sure the audio setting is set to AC97 or Auto. Save and exit the bios. After restart check for sound. If your using front panel audio instead of the rear audio jacks. See pages 37 & 38 in your manual for proper setup.
For rear MB sound out put only. See page 38 in manual.
Check for audio.
If rear and or front audio fails to function the the audio chip is defective.
Questions?
Mike
Sep 03, 2010 | Intel D101GGC Motherboard
Intel(r) 82801AA AC97 Audio Controller Audio Driver for Windows 98 is needed for the above embedded chipset
Install this driver from Intel Site:
Audio: ADI* Soundmax* Driver for 815 Chipset-Based Boards
Integrated audio driver for Intel desktop boards using AC '97 for Windows 98.
@ http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
Hope it helps.
Aug 05, 2010 | Computers & Internet
C-Media AC97 Audio Device
Hello there:
If you are looking for the driver simply go www. vinal ac97.com and there wil be a full page of different ac97 downloads for you there ok?
hope this is very helpful for you
best regards michael
Dec 31, 2009 | Intel XTERNote MS2117 Notebook
Sound drivers
u can try this if u understand
http://support.fujitsu-siemens.com/Download/ShowDescription.asp?SoftwareGUID=CB518FBD-386C-4266-8730-432160E331E7
or if u have the drivers and utilities cd with u,u can install the drivers from that disk also,or check this out
http://www.helpdrivers.com/ingles/doc/instal.htm
try this out
Go here and enter your details...
http://www.fujitsu-siemens.com/support/linkapplication.html?LNG=EN&ID=263
Try Everest Home Edition (for free but you've got to Google for it)) and then to driverguide.com to pick it up, if the Fujitsu site doesn't help with it.
u need to install this driver for ur audio for the laptop
AC97 Compliant CODEC: Conexant Cx20468 driver:-)
Now try again here and click on c1020...
http://www.fujitsu-siemens.com/support/linkapplication.html?lng=en&id=263
and when u install the driver from griverguide.com follow this
After you installed the latest VIA AC'97 Enhanced Audio Controller driver from Driverguide.com , did you check the Device Manager?
What is seen in + Audio video and games Controllers?
Since you have tried to install other drivers, I am wondering if you could have corrupted the drivers.
If you have got the Right Drivers saved , I would suggest the following:
1. Start the Computer in Safe Mode
2. Open Device Manager> + Sound, video, and game controllers
3.Uninstall everything EXCEPT audio codecs, Legacy Audio Drivers and Video Codecs
4. Close Device Manager
5. Restart the Computer.
6. When the new hardware found message comes direct the wizard to the downloaded driver for installation
the audio controller is audio controller is a VIA VT8233 AC97 Audio Controller. VIA Technology website and download the VT8233 drive and it will definately work...good luck
Jan 27, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Audio
Hi Hasan007, download your manual for your FIC VC 11 at this link. http://taiwan.fic.com.tw/support/download.aspx?dl=motherboard%2fmanual%2fsocket478%2fvc11%2fvc11_a0_eng.zip&title=vc11_a0_eng.zip&info=manual
Your board is supported by the Intel chipset 845. Intel is supposed to include the intergrated PCI sound card driver for the, AC97 ICH2 audio controller along with the video controller. This link should get you to the AC97 driver.
ftp://ftp.fic.com.tw/motherboard/driver/1stUtilities_v1.0/AUDIO/SIGMATEL/
Started the ftp here, opening the first folder top of the page.
Once you get the correct driver (Sigmatel/AC97), your sound should work.
Good Luck!
Mike
Apr 04, 2008 | FIC VC 11 Motherboard
Fujitsu LifeBook S4510 Notebook Logo
232 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
