When i switch on my laptop a black screen just appears and BOOTMGR is missing, i have tried to use the recovery disc but found that this wont fully install either
  • 1 more comment
  • rachael_rain Mar 07, 2009
    when i put the disc in, everything is normal then i come to a screen that says language, i do that and then click repair computer, then startup repair. This loads for a while and then says startup repair can not repair this computer automatically :(
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    If you are still under warranty I would get it serviced .. It sounds like a hard drive problem ..
  • Jay Glendenning
    What happens when you try to use the recovery disk? You state that it "wont fully install" .. What do you mean by that?
  • 479 Answers
this seems to be a hdd issue so get it serviced.
Posted on Mar 07, 2009
Compaq Preario CQ56-115DX Notebook wont restart
If your bootmgr is missing and you have windows 7 you should have a repair partition that can be booted into using the F8 key when powering on your machine. If not, you will need a repair/recovery/installation disc to boot from
Mar 23, 2013 | Computers & Internet
Bootmgr missing error on startup
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Oct 09, 2012 | Dell Studio 1737 Laptop
Bootmgr is missing
That is unfortunate, the recovery disc is the only option at this point to reload the operational system. Go online to Toshiba and contact customer support and the technical department to see if you can purchase a recovery disc for your make and model.
Apr 08, 2012 | Toshiba Satellite Computers & Internet
Missing bootmger
Fixing the "BOOTMGR is missing" error isn't too hard; here's how.
The day before yesterday I was testing out a program with several system utilities built in. One of its components left my computer in a bit of a mess - no icons anywhere and other assorted woes. I had set a system restore point before I ran the program, so I thought I'd do a system restore. System restore gave me a message that it couldn't restore my files. I decided to restore a disc image I had made a short while back. When I booted up the computer I got a message:
BOOTMGR is missing
Press Ctrl+Alt+Del to restart
I stared at it the white letters on the black background for a few minutes, while the cursor blinked back at me. After some searching (on another computer) I had some solutions.
Barring any hardware errors, here's how to fix that error:
  • Insert your Windows Vista or Windows 7 disk into your DVD player and restart your computer.
  • The next screen you see should have the Language, Time and Currency and Keyboard boxes.
  • In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
  • Click on "Repair your computer"
  • Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
  • Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
  • You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
  • When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
  • At this point, you can remove the DVD, reboot and everything should be working.
Two sites I found helpful are BOOTMGR is Missing at about.com and cyberstorms How to fix "BOOTMGR is missing" in Windows Vista
If the method outlined above doesn't work, try Solution #2 at the cyberstorm link.
Oh, restoring the disc image went fine and all is well. All my data was backed up (somewhere other than the hard drive Windows is on) so that was one thing I didn't need to worry about. Windows Vista and Windows 7 are the only Windows operating systems where this message appears; XP users don't have to worry about this one.
Mar 29, 2011 | Computers & Internet
Bootmgr is missing
BOOTMGR is missing
Feb 18, 2011 | Acer Computers & Internet
I have hp pavilion dv6000 i had a problem about recovery manager
Did you attempt to load recovery/factory image from hidden partition and if so did you follow User Manual or Guide re instruvtions? if so there should have been no problems. I would try again though do it slowly and carefully when choosing Options so that you don't change Partitions where the Default Software is.
Was it Alt and F10 buttons when powering up from a Shutdown, i.e Cold Boot?
Apr 09, 2009 | HP Pavilion dv2000t Notebook
My HP dv2000 will not boot the screen says BOOTMGR is missing
you need the Operating System Disc or possibly boot to your recovery partition.. try holding F10 or F11 Upon boot to take you to the recovery screen if it is still there...
Nov 20, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
384 people viewed this question
David Payne
David Payne
