Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
I'm on cable, what do I need to do to better hd pictures
See above
  • 112 Answers
Get a HD box and cables.
Posted on Mar 07, 2009
How to hook up to t v
If you have a new model HD is better if you use and HDMI cable. Better picture and sound. If not you need to set the av cables in the right places.
Jun 13, 2010 | Sony Playstation 3 (PS3) Console
Does the Sylvania 22 HDTV require a special cable when connecting to my cable service. I do not have HD cable service.
Not necessarily. You can use the normal connecting cable but you may not get HDTV picture. Better is to connect through HDMI cable where you can view HD pitures on the channels transmitting HD programmes
Jan 06, 2010 | Sylvania LC-225SL9 22 in. LCD TV
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Picture quality
Are you viewing HD or standard definition.
Generally, LCD tvs don't do well with "standard" signals, since they're designed for HD.
You may get a slightly better picture by replacing the cable that connects from your TV to cable box, and cable box to wall. However, if you're not watching HD, it's unlikely that you'll notice the better cable making a big difference.
Mar 19, 2009 | JVC LT-42X579 42 in. LCD TV
Is tv an HD tv
Yes, mostly all new displays are at least 720p which display a great picture ! However, coax cable is the worst possible cable you can use. Your best bet for HD from the cable box is to use component cable. These are the 3 RCA type colored cables, red, green and blue. You will also need another two RCA cables for the audio, which is usually red/black or red/white. If you have a surround sound receiver, then you will not need the 2 for audio to the TV. These 2 would goto the receiver or you can use a better digital coax or optical cable for audio.
Also, HDMI from the cable box to display is a more expensive cable which will give you HD but doesn't always look better then component on some HD cable boxes.
Mar 11, 2009 | Philips Televison & Video
HDMI Connection
Yes it does, HDMI can handle more information and provide better picture and sound. Works like this, Cable-OK, Component-Even Better, HDMI and DVI-both Digital and the best sound and video. The only way to get full HD is with HDMI or DVI. Hope this helps
Jan 17, 2009 | Philips 52 In. LCD HDTV
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
HD Channels have grey strip above and below picture?
If the problem does not occur on ordinary channel please contact your local station and ask for the proper settings for viewing HD in your area.
You need HD cable to go from your top box to your tv.
Jan 05, 2008 | Mitsubishi WD-73734 73" Television
2002 Sony 57 inch XBR
YOU MAY NOT HAVE THE HD COMPONENT CABLES AND CONNECT THEM TO ONE OF THE VIDEO LINES..
Dec 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
