Question about HP LaserJet 6L Printer
Data Cord Problem
Actually I have bought a new laptop but printer using 6L having comport but laptop has a USB so how can i connect my printer with laptop or any type of USB data cord is available in the market
    Genius:
  • 2,120 Answers
You need a Centronics to USB Cable
Posted on Mar 07, 2009
Usb to serial. will it work with a compaq laptop and an hp 6l printer?
I think you mean usb to parallel....and the answer is maybe.
Usb to parallel adapters don't always work with all printers. Buy one from a store that will let you return it if it doesn't work. Make sure you install the drivers for the adapter as per the instructions that come with it.
Hope this helps,
Regards,
Joe
Jan 04, 2011 | HP LaserJet 6L Printer
I bought a Laseret 6L and a usb adaptor cord to replace the parellel port connection on the computer end. I've tried every suggestion regarding ports, but nothing works. The test page prints OK, but...
I've heard there is special software needed to do the USB to parallel conversion. We have a customer using a LJ 1000 with this hook up and there is supposed to be a driver/conversion software that handles the issue. Here is a good discussion that may have some solutions for you.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1268956879623+28353475&threadId=1087380
Mar 18, 2010 | HP LaserJet 6L Printer
The USB ports on my Toshiba A135 S2356 laptop are not working. I tried to use my printer and it says not connected. I bought a new cord but it still doesn't work. What should I do?
1. first check ur USB port using any other USB device, like pen drive, mouse, keyboard,etc.
if system detects that device, then ur USB port is OK!
2. if USB is OK, then the problem is with the 'Printer Driver' not the cord!
3. reinstall the printer driver!
4. update the driver!
5. if USB port is not working, then replace it!
if this helps, tell me.......
Dec 30, 2009 | Computers & Internet
LaserJet 6L with Vista using Parallel to USB Cable
It can be done tested by Thoo personally 6L printer prints well on vista too
The printer end should be connected to 25 pin parallel cable, converted to the USB on the notebook end of the wiring
To solve your printing problems locate vista driver, since i have tested vista works fine on HP 6L printers
make sure you select the correct O/S and assign in to the USB virtual port 05
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
After installing my vista can print perfectly well on test printout
Advise from http://www.bebo.com/andythoo
Technical support specialist: Thoo Wai Kiat
Nov 05, 2008 | HP LaserJet 6L Printer
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
Officejet G85 printer
If you previously were using a parallel connection for the G85 you will need a USB cable.
If your laptop is running Vista the G85 will work as a printer, I do not think there is a scanner driver for Vista for the G85. The G85 print driver is built into VIsta, you only need to turn on the printer and install the USB to have the printer automatically installed.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
HP laserjet 6L
Get it cleaned in paper sensor area and check up the drivers as well as data cable which connects, the pc and printer. Change the data cable if necessary. Give me feedback so that may be some more help can be provided.
Mar 12, 2007 | HP LaserJet 6L Printer
HP LaserJet 6L Printer Logo
69 people viewed this question
Ben Johnson
