Question about Philips DVDR3450H DVD Recorder/HDD Recorder
Disc drawer says BLOCKED and will not open. No disc is inserted
I had the same problem . I had to take the outer casing off and was able to open. to keep this from happining again I always leave a disc in the disc drawer it seems to solve the problem
Posted on Mar 29, 2009
2 Suggested Answers
SOURCE: Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
Posted on Aug 21, 2009
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
Hi, I need a pioneer dvl-909 service manual that tells how to replace the loading belt. Thanks, Bill
Try to see if the drawers are blocked by something either inside or outside of the case.
Mar 17, 2012 | Pioneer DVL-909 DVD Player
Pioneer Comp Disc Player PD-101 5R . MI 7507855 ME. MFD Sep 1992
remove the jacket of the player and open the draw
Jun 20, 2009 | Computers & Internet
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Kenwood dv-505 door will not open
THERE IS AN EMERGENCY OPEN OPTION ON MOST ALL DISK DRIVES, LOOK RIGHT BELOW THE DRAWER USUALLY TO THE RIGHT FOR A SMALL PINHOLE. GET A PAPER CLIP AND STRAIGHTEN ONE END OUT, INSERT STRAIGHT INTO HOLE UINTIL YOU FEEL IT STOP AT THE MANUAL RELEASE CATCH AND GENTLY PRESS UNTIL YOU HEAR THE DRAWER BEGIN TO OPEN.
BLOW ANY DUST OUT, AND CHECK THE PC AND DRIVE WEBSITE FOR A POSSIBLE FLASH UPDATE FOR YOUR DRIVE MODEL. THEY ARE OFTEN POSTED WHEN DRIVES SHOW PROBLEMS READING SOME OF THE NEWER DISK BEING MADE. THIS HAS WORKED FOR ME A FEW TIMES IN THE PAST.
Feb 13, 2009 | Compaq Evo N610C Notebook
Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Jan 11, 2009 | NAD C521 CD Player
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Sony drive how do you insert disc?
No such thing as a stupid question! There will be some type of button beside the drive drawer. If not, click on my computer, right click on dvd/cd drive, could be called drive E but that is different for different machines. Select eject. The drive drawer will open so you can put the disk in.
Jan 06, 2008 | Computers & Internet
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
784 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
