Question about Sony PSP (Piano Black)
I cannot transfer games from my pc to my psp
Do i need any necessary steps
  • Anonymous Mar 08, 2009
    me too
  • Cheslyn Pillay Mar 18, 2009
    where do you find the cso folder on your psp in order to copy your game to?
    Problem Solver:
  • 11 Answers
YES ! you NEED NECESSARY steps that ARE : 1. you must have a cable or memory stick to put it in your psp 2. you must have some folder in ur psp if not FORMAT the memory stick using the psp (the psp will put the folders by itself ! 3. put the game in CSO folder ! and then disconnect the cable ! and enjoy the GAME !
Posted on Mar 14, 2009
How to download a games to a psp version 6.10
How to Download Games onto PSP- Step 1-
Your regular PSP games will come on disc, or UMD as they are known. When you download games onto PSP however, you are going to be putting them straight onto a memory stick/card. (Some people call them memory sticks, and some people say memory cards, but they are in fact the same thing.) The standard PSP memory card of 32mb is just not going to be big enough to download games onto, PSP owners should generally get the largest one they can afford. These days you can find fairly affordable 2 or 4 gig models on Ebay and Amazon quite easily. Once you have your new memory card, you will need to format it before use. This is basically like wiping the slate clean before use, so be sure to do it.
How to Download Games onto PSP-Step 2-
You will need to locate somewhere to download the games from. There are hundreds of places online that will allow you to download games onto PSP, but unfortunately they are not all reliable-if you go to the wrong places you will encounter many problems and can even find your computer riddled with spyware after. Not good! Be sure to choose a reputable site to download PSP games from-the most reliable ones are the ones that charge a small fee upfront and then give you access to unlimited downloads.
How to Download Games onto PSP-Step-3-
Once you begin downloading to your computer, be sure to only download files that end in "PSP" or have "PSP" in the title, as they are the only files compatible. You will occasionally find that the untrustworthy sites out there will try and give all kinds of files as downloads, so be sure to double check everything before you download it. When downloading the games I save them to a little folder on my desktop called "PSP Downloads, as it's simply the easiest place!
How to Download Games onto PSP-Step 4-
Now that you have a selection of games downloaded, you will need to transfer them from your PC onto the memory card of your PSP. This is pretty simple, all you will need is an ordinary USB cable to connect the two, and the PC should then identify the PSP as some form of removable drive, like a flashdrive or removable HD. All you need to do from here is to open up the PSP using the PC and drag and drop the required files onto the PSP memory stick, much as you would with any other removable drive. When you are doing this, be sure to send the files into folders called PSP, and then GAME on your memory card. If they don't exist you will need to create them, and I would recommend using all caps.
How to Download Games onto PSP-Step 6-
Once the transfer is finished you should be able to play the games on the PSP by simply opening up the GAME menu and selecting the games from the stick. Any errors or error messages are likely to be due to incompatible firmware-this is especially true if downloading homebrew games. You may find it necessary to downgrade your PSP in order to play these homebrew games.
Hopefully this guide has helped you see that it's not that tough at all to download games onto PSP once you get the hang of it, the real trick is finding a reliable download source!
I would suggest downloading PSP games using torrents. Just go to www.thepiratebay.org and search for PSP games. You'll need to have mutorrent or some other torrent software on your computer to download the torrents with. Follow the instructions once you have the downloaded game via a torrent and you'll be good to go. Good luck.
Mar 13, 2011 | Sony PlayStation Portable Slim Black...
How to downloads games PSP-1001 from PC?
Hello
To download games to your PSP You will download your PSP games from the internet into your PC and then transfer your PSP game files to your PSP using a USB cable. After your computer is connected to your PSP, your PC will recognize your PSP as a detachable memory drive (similar to an external hard drive). It will assign your PSP with a drive letter (usually F: ) which will allow you to drag and drop you PSP games file from your computer's hard drive to your PSP memory stick. Below are some of the steps to download PSP games.
Step 1: You must copy your PSP games file to the correct path or the games simply would not work. The correct path is PSP>GAME (all the folder names are in caps)
Step 2: After the PSP games are fully transferred to your memory stick, disconnect the PSP from your PC. In your PSP main menu, scroll to GAME and then select Memory Stick option. Press X, and list of available games in your memory stick will be displayed. If you find any error on your PSP, you might want to check your firmware version.
Good luck
Jan 15, 2011 | Sony PlayStation Portable (PSP) Console
How to download psp games into my pc
Hi there, I came across an article which explains how to transfer PSP Data to your PC.
CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
FORMAT YOUR MEMORY STICK
In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
EXTRACT THE SAVED GAME
This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
VERIFY TRANSFER OF SAVE DATA
To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
Jan 01, 2011 | Sony PSP (Piano Black)
How to play my psx game on my psp
This is a problem occurring in all the play station consoles....... this is mainly because of the poor quality of the disc.....as a result it leads to the damage of ur PSP lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Aug 11, 2010 | Computers & Internet
How can we download psp games now
these are the steps you will use to download a game on your psp.
step 1
step 2
step 3
step 4
step 5
Please rate my solution.
Thanks
Jun 26, 2010 | Sony PlayStation Portable (PSP) Console
What are the procedures to download a game from my psp through internet?
In simple terms its this; you will download your games from the internet into you PC and then transfer your game files to your PSP via a USB cable. When your computer is connected to your PSP, your PC will recognize your PSP as a detachable memory (similar to a USB drive). It will assign a drive (usually f: ) and you will be able to drag and drop you PSP games file to your memory stick. These are some of the step to download PSP games.
Step 1
Step 2
This is a simple guide on how to download PSP games from your computer and it is a proven techniques and been done countless of times. Most important of all it allows you to enjoy wide variety of games from other gaming console.
Nov 04, 2009 | Sony PlayStation Portable (PSP) Slim...
Transferring pictures,videos,movies and games to PSP from Comp
Connect the PSP to the PC via the provided USB cable, then you can transfer the Video from the PC to the PSP
Dec 19, 2008 | Sony PlayStation Portable (PSP) Console
How to get music on my psp
http://psp.about.com/od/music/ht/howtransmusic.htm
click on this link and follow the instructions. This will explain step-by-step on how to transfer music.
I hope this helps
Dec 05, 2008 | Sony PlayStation Portable (PSP) Console
Hey i have prob in iso games
STEP 1: CONNECT YOUR PSP TO PC
STEP 2: FORMAT YOUR MEMORY STICK
STEP 3: EXTRACT THE SAVED GAME
STEP 4: TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
STEP 5: EXIT USB MODE
STEP 6: VERIFY TRANSFER OF SAVE DATA
That's it, simple and smooth.
Oct 16, 2008 | Sony PlayStation Portable (PSP) Console
Transfering psp games from external to memory card of psp
Psp game console using cd or dvd disk what's different from others why?
These are codecs securing facts and should not downloading it by internet. You will catch some viruses!
You need to have installed codes for psp games cd-s.
That's like software who is unlock the codes that pc can recognizes and transfer them to the psp.Thats not really easy to find for free.
Jun 10, 2008 | Microsoft Windows Vista Ultimate Edition
Sony PSP (Piano Black) Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
