Question about Garden
Need manual on how to put Yard Machine models 410 & 420 rear tine tillers gear case back together.
  • Anonymous Mar 22, 2009
    I Need a manual on how to put Yard Machine models 410 gear case back together.
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
The cluch doesn't work. The gear pointer doesn't
Do you have a model number? Front tine or rear tine? I will try to help you.
May 29, 2010 | Mtd Products Yard Machines 158CC Tiller
MTD Series 410 rear tine tiller. Tines won't engage.
I had the same problem. After splitting the case, I found that the shifting fork was bent and the pins that move the shift collar were worn. I made new pins for and reinforced the shifting fork, put it back together and if worked for a few minutes until it would jump out of gear while tilling. I would try to hold the external shifting rod down so that it would not jump out of gear but eventually it quit working completely. I tore it down again and the pins were already work out. I ordered a new detent ball and spring for less than $10 including shipping. This seems to have cured the problem. Apparently the detent spring was weak which allowed the shifting collar to disengage from the drive gear when under load. The original spring had been replaced with a new part number so it may have been made stronger. Tearing one apart is not easy but is certainly doable. To make it easier, put the nuts back on the bolts from where they came. Also get the parts manual picture to help with reassembly. Be careful with the case gasket. It costs a ton for a new one but since the grease is so thick, you could probably silicone it back together if you destroy the gasket.
Apr 19, 2010 | Mtd Garden
Need manual....for 917293401. took it apart and can not put back together
here ya go! go to this page and there is 7 blue links to choose handles,frame,transmissin,ect..each has pictures and part numbers
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=917.293401
  • CRAFTSMAN
  • REAR TINE TILLER
  • Model# 917293401
Browse Subcomponents To make your search easier, we have grouped this model's parts into subcomponents. Please choose a category below to view the related parts and diagrams.
r3_placement('category_page.bottom_modelsearch'); r3_placement('category_page.bottom_modelsearch');
Aug 28, 2009 | Craftsman 8.50 Torque Rating Dual...
I have a lazy boy tiller with chaine drive, its liked locked up. it will not engage, any help please ! it does have aplace to put oil on the side of the chine drive house. what kind of oil would it take?...
The gear box can be removed, reset and resealed using gasket magic. It is not a quick fix and during this process I also replaced the tine shaft seals as I had lubricant leaking from the gear-box to the tine shaft. When you are tilling you should avoid rocky areas. It iseems sudden tension due to bouncing is what knocks the chain loose.
DO NOT remove the belt pulley from the top of the gear box. It is unecessary. You must remove the entire assembly from the rear of the machine. It is set in place by 6 bolts and come off as a whole unit. Once it is removed then undo the three bolts and spacers that hold the case in place. Remove the case from the frame by sliding it out the open end. You will have to remove all of the bolts around the outside of the case; a cordless drill really comes in handy here. Lay the case on its side, as you remove the bolts you may experience lubricant dripping from the centers of the removed bolt holes, or at the center holes where the case connected to the frame. This is not a problem as you will need to replace the 90 weight lubricant after you have resealed the case anyway. Once you have removed all of the bolts, using a flathead screwdriver and a mallet or hammer. break the seal around the outside of the case. You may have to go around a few times, but eventually it will pull apart revealing the sprockets, bound chain and remaining lubricant. Since it is open this is an ideal time to check for wear on sprockets and remove any large debris from the case. reset the chain so that the tine shaft moves freely and the corresponding sprockets spin as you move the tine shaft. Using a gasket sealant (Gasket Magic**) put a thick bead of sealant in the center of flat outside edge where the two sides of the case come together. Add a little extra around bolt holes. Replace the two covers snugly together and begin finger-tightening the bolts back into the crank case. Once you have completed this task, go back over the bolts and tighten with a hand wrench. Once the case is back together allow 45m to an hour for the sealant to completly harden before introducing lubricant to the system. Then reattach the case to the rear assembly and then put your tiller back together.
This occurrence seams to be an issue with these machines, however the problem is avoidable as it is persistant use in rocky or hard ground areas which causes causes the system to jump and bind. If you happen upon a hard patch of earth or rocky area, go slow, do not force the tiller and remove any large debris when possible before tilling.
Jun 16, 2009 | Garden
MTD yard machine model#216-410-000
either your tine shaft is seized to bushings which requires total dissassembly of unit or you have a failure of drive chain or gear i'm currently repairing one with the seized bushings if you are not a technician i would recomend replaceing unit very costly to repair in any case.
Apr 05, 2009 | Mtd Products Yard Machines 158CC Tiller
Sep 28, 2008 | Mtd Super Bronco Rt Tiller
Garden Logo
321 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
