All my speakers are connected correctley.. when i switch them on the power comes on but i cant hear no sound?
  • 245 Answers
Check if ur speakers are not muted.....go to control panel and select sound device....make sure sound is ticked....
Posted on Mar 07, 2009
My cb radio is on but cant hear nothing sound is turn up but nothing come out
You didn't include the make / model CB you have, so I can only offer general suggestions. If these do not work, please provided the missing info.
Start out by locating and setting the the Volume to a position between 1/4 and 1/2 way clockwise, the Squelch to fully counter-clockwise and the "RF Gain" to fully clockwise to "MAX".
Check the position of the "PA / CB" switch and set to CB. When set to PA, both receive and transmit audio is sent directly to an outdoor speaker (instead of through the transmitter and antenna for reception by other radios). The PA speaker is usually connected to a jack at the rear of the radio. When the PA / CB switch is selected, the internal speaker is silenced even if there is no PA speaker connected.
At this point, you should hear static or voices (with an antenna connected). Do not attempt to transmit without a properly tuned antenna connected. If no sound is heard, there's something else wrong.
May 22, 2012 | Uniden Pc 78xl Cb Radio Mobile
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
Why wont my sound come out from the speakers you cant hear nothing from the speakers it turns on and everything but no sound
if you have a factory amplifier you have to connect the blue wire from the amplifier plug into the power wire for the player
Jul 14, 2010 | XO Vision XOD1735 Car DVD Player
Cant hear audio when switched to enhanced mode. no audio when testing subwoofer or center speaker
You say this is a 5.1 system. Five satellite speakers and 1 Bass woofer. Do you have a 5.1 or better sound card? If so, have you connected all of the colored plugs to your sound card? If your sound card only has 3 to 4 audio connections you will not be able to run in enhanced mode.
Mar 09, 2010 | Sicuro RealWorld 670XL-BK 5.1 Gaming...
NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Jul 12, 2009 | Music
TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Feb 14, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Audio do not play
Unplug speaker connection. Go to Control Panel, double-click on "Sounds and Audio Devices" and on "Volume" tab make sure "mute" is not checked and that volume is sufficiently up there. If thats ok select "Sounds" tab and go to "Program events", select any Windows sounds and check to see if you can hear the sound by clicking on the arrow next to it. If you can hear sound its ok so then check your speakers connection to correct sound output jack and that external speaker is powered on.
Dec 29, 2008 | Dell Latitude D500 Notebook
New behringer powered mixer, comes on, but doesn't hear anything.
Fan comes on with temperature rise. Not a problem if off till you start driving speakers loud.
Make sure standby switch is up. The slide switch is up to A/B.
The main fader iis up. Your input fader(s) are up. The trim controls are up enough. Inputs are plugged to input and not the inserts.
Be careful... this unit has a lot of power and can blow speakers.
Nov 23, 2008 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Cant hear my cable channels through my surround sound...
Hello, i just saw your post.. i know this reply is so late, and you might have probably found a solution. But i will still give you some guides to help you figure this out.
(1) First and foremost, make sure your connections are set up properly (exactly as in the manual). most HDTV'S require a DIGITAL OPTICAL CABLE to be connected from TV to receiver. Read the manual on your TV and see the required wires for external audio
(2) go to your TV audio settings. Get to the speaker option, and turn it off ( this assumes your expensive TV is an HDTV). By turning it off, you signify that you want the sound option to come only from the speakers.
Hope it helps
Oct 09, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
I cant hear no sound
please check the following:-1-power plug is connected to wall outlet.
2-it is switched on,3- sound source is selected(dvd-cd-vcr)4-volume level not in low position-setup of speaker is properly set.5-speakers cables are firmly connected.6-no mute switch is depressed.
7-speaker button is depressed.
Jul 22, 2008 | Audio Players & Recorders
63 people viewed this question
