Question about Karcher K2.26 Electric Power Washer
Karcher pressure washer 411A. loss of pressure...
Hi folks....any suggestions....polite or otherwise please...
Karcher 411A...getting on a bit now.... loss of pressure...replaced 2 broken piston springs in pump...now have approx one third of pressure that it used to be.....anyone know where I can get a detailed diag of pump...may have rebuilt it incorrectly !...or any other suggestions always welcomed...Thanks for looking
  • Anonymous Mar 26, 2009
    Ihave a karcher pressure washer ,the intake output valve is leking and i need to get one waer can i get it karcher 330
  • Anonymous Mar 15, 2014
    loss of pressure
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
Where can I get a Karcher 410 spray nozzle (bit on end of wand) Karcher don't seem to keep such an old part.
Hi Stephen:
Don't know where you are, but in my location here in Canada, the local LORDCO parts store has a large selection of pressure washer accessories.
I'd suggest that you try to find a similar equipment supply retailer.
Cheers
Nov 06, 2015 | Karcher Garden
Loss of pressure
Check for possible loose connections, its possible it could be leaking which would cause the loss of pressure.
Aug 09, 2009 | Karcher K2.26 Electric Power Washer
I have tried to use my Karcher washer model 411A using the suction tube which is immersed into Patio cleaner bottle but it does not work what am I doing wrong
you have to lower the pressure at the lance for the detergent to be drawn into the hose. It works on a venturi principle.
on the lance you will have to twist or pull back the end for it to go into low pressure mode.
the easiest way to check it is working is to take out the lance extension , the bit that fits into the trigger on a bayonet fitting. run the machine and see if it then draws in detergent.
If it doesnt draw detergent then look to see if there is a detergent valve fitted to the filter that goes into the bottle and check that it is fully open. sometimes ther is a non return valve fitted into the filter too.
it could be that this non return valve has stuck. A poke with a bit of stiff wire should free it off its seat if it is that problem.
hope this helps a little
Jul 17, 2009 | Alfred Karcher Pressure Washer
Loss of pressure
give me a more detailed explanation of how this happened and what you've tried
Jun 14, 2009 | Karcher K2.26 Electric Power Washer
Karcher k7.91 pressure washer /loss of pressure
if the motor will not turn on ,thers a problem with the current excess switch , which is situated under the main power on of swith hi needs to be replced
May 04, 2009 | Karcher PSI Electric Pressure Washer
My karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Apr 25, 2009 | Karcher Garden
Karcher K2.26 Electric Power Washer Logo
1,923 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
