Question about Dishwashers
Whirlpool Adg957 dishwasher door not closing
When go to shut door and will not shut just springs back open
  • lmcouto Apr 29, 2009
    "whirlpool Adg957 dishwasher door not closing"
    I took out the machine and also both side panels. I could see both springs were out, a plastic piece and a metal stripe were broken!
    Can anyone explain...step by step...how I put it on the right place again?
    Thanks
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
dutchman05
  • 487 Answers
SOURCE: problem with whirlpool dishwasher ADG957
Continuous flash with no pause is a Faulty NTC (temperature sensor)
Or according to whirlpool it might be that your keys are syticking.
Posted on May 07, 2008
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
SOURCE: Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Posted on Aug 24, 2009
Testimonial: "Hey, thanks for the advice. Worked like a charm. Hopefully Frigidaire has improved their design."
SOURCE: The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
Posted on Dec 02, 2009
I have a problem with my CDW60W13 Currys Essential dishwasher. The door will not click shut and springs open. I've had a look at the locking mechanism and can see nothing wrong.
There is usually a little latch on those mechanism to keep the door closed. If the latch breaks, the lock spring just pops the door back open when you attempt to close it.
I would repair the lock mechanism. Try appliancepartspros.com for the part.
Aug 29, 2015 | Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Installing dishwasher WDT710PAYM door will not open
It is likely the door springs at the base are too tight and holing back. The installation instructions show how to release the door springs.
If you do not have these instructions then download from this site.
http://www.manualowl.com/m/Whirlpool/WDT710PAYM/Manual/221751
Jun 12, 2014 | Whirlpool WDT710PAYM Dishwashers : Built...
Cold storage door will not stay shut
all of the refrigerator has a spring if there has no spring it will not open and close!
Apr 14, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The detergent door doesn't pop open.
If you push the door closed not far enough to latch and let go of it does it spring back open if not the spring on the dispencer door is broken or has fell off
Mar 31, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Problem with whirlpool dishwasher ADG957
May 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool g2p dwi
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
Feb 17, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
249 people viewed this question
Top Dishwashers Experts
