Question about Kenmore Washing Machines
Washer is making a loud banging noise..
I've had the washer for about 5 years. I went to use it one day and by the time it reached the rinse cycle it was making a loud banging noise. I went to check on it and there was a burning smell.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
The washer is a Kenmore, front load style, from 2003.I would like to know if I really need to replace my washer, or a repair is feasible at all.
Have a service engineer to come and have a look and assess the extent of the problem, depending on the issue he will be in a position to tell you.
After that it depends on how old it is etc...
Aug 10, 2015 | Washing Machines
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
My GE wjre5550h1ww waher makes a continuos loud clank/bang noise when time the washer is in the soak/agitator cycle. Rinse and spine cycle, normal noise/sound. Please help! Thanks
The part (it has three prongs) that the transmission (yes your washing machine has a transmission) uses to cause the reciprocating motion of agitation has broken off 1 or 2 of the 3 prongs, and, if you
continue to use the washer (you might as well, the part is broken already - you may as well run it until it dies), the part will break completely, and you'll lose the soak/agitator cycle altogether.
FIX: replace the broken 3-prong plate, and give it a nice coating of automotive bearing grease to help it last for awhile (until the next thing breaks).
Dec 11, 2010 | GE WBSR3140DW Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer got unbalanced, since makes noise on spin,rinse cycle
first try your filter if there is one then check your pump
Mar 03, 2010 | Washing Machines
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Washing Machines Logo
98 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
