The lint filter is behind the lower panel, under the washer's door. Remove the three Phillips screws and locate the round white "plug" shown above. Be sure to have a bucket or large bowl to catch water, as there's a LOT of water in there. See my above comment posted June 29th.
Don't believe it has one. I have only noticed that when you open the door, at the very bottom rubber you can pull towards you and should find objects that at times we forget to take out of our clothing. Coins, Screws, ect. Also, you can remove the bottom plate which has two screws. Once you remove, on your right you will see a knob type of handle. Note: water will come out when removed. Unscrew and there you will find anything that has slipped through and hasn't gone into the pump.
my washer is not completing the spin cycle. i think it's because the lint trap needs to be cleaned out. I can't find it.
Remove the lower front panel using a Phillips screwdriver. You'll see a round "plug" there, just right of center. Unscrew it VERY SLOWLY, keeping a large bowl or bucket to catch the water. Be ready to screw it back in to empty the container, as there's a LOT of water there. Once it stops coming out, unscrew it and pull it out. Clean debris from the plastic filter and check inside to make sure it's all clear, then screw it back in snugly and replace front panel.
