Question about Compaq Presario M2000 Notebook
Compaq m2000 battery not charging.
My compaq m2000 notebook battery is not charging. i replace a new battery, still the problem remains. please get me a solution.
  • Anonymous Mar 24, 2009
    same thing
  • Asif Raza Mar 27, 2009
    I am facing a same problem with my notebook its just working on AC Adaptor and if i unplugged it turn off in 6-7 minutes. Another problem with me is that my DVD ROM is not working properly it does not read any CD???? Is that a LENS problem??? Is there any solution in stead of replacement of new DVD ROM. LENS can be repared?
Battary nikal ke dubara lagao
tinner dalo lens main.
Posted on May 06, 2009
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
My presario M2000 will not star orf come on. It has a new battery & power adapter.It gets very heated when charging. Helpme ???
Make sure you have an original adapter. Some of the REPLACEMENT adapters do not work very well with these computers.
ALSO make sure you have the right replacement battery. For instance in the {ressario 3000 series, there are two different batteries and one will work with some machines, but the higher level machine requires a bigger battery, although it is in an identical case.
Nov 28, 2009 | Compaq Presario M2000 Notebook
MY presario M2000 notebook will not power on.
how about the battery of the laptop, have you aleady check it? if you can find a working identical laptop like the one that try using the battery and see what happens if it will work or not, if it work then you have a battery problem and needs replacement
My compaq presario m2000 will not hold a charge it will say that its charging but once it gets to about 36% it says it discharging
let the battery completely discharge, then fully recharge. Do this at lease two. After it has fully charge the last time, see how long it takes to disgharge. It should be somewhat better. If that does not work your battery is shot and needs replacing.
Sep 14, 2009 | Compaq Presario M2000 Notebook
Turn on a s/h presario m2000 and it asks for a password of which i dont know what do i do`
try pressing esc. two times.
Or type admin for username or admin for password. Or try password for password.
Jul 04, 2009 | Compaq Presario M2000 Notebook
Compaq M2000 charges battery, but from batt or
The best sollution is to call your vendor for sollution, everything you can do to solve would void youe waranty
Jun 21, 2009 | Compaq Presario M2000 Notebook
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
256 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
