Question about Epson Stylus Photo R1800 InkJet Printer
Electrical The printer starts up perfect but when I than pess the print button the printerhead rapedly gos to the left side and the power turns off. Can you solv this? Thanks Jan-Henric Andersson, SWEDEN
  • Epson Master
  • 419 Answers
The printhead may have lost it's connection to one of the flat ribbon cables that normally goes into the back where a small circuit board and sensor read the printhead's location.
The cable is brown, very thin & wide and needs to be pushed carefully back into the receiver to get a connection.
This is just a guess but it's a similar behaviour to the C86 which did this when my CIS knocked the ribbon cable out of position and the printhead became "lost" or "blind".
Hope that helps.
Posted on Mar 13, 2009
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson LX 300 printer. every line, starting
Try to check your printerhead it could be damage due to over use or old printerhead. Just replace your printerhead to print it normal.
May 29, 2010 | Epson LX-300 Matrix Printer
Will not print---all I get is a blank paper
Try to check the ink of your printer that they have more ink inside. Or els just check the printerhead of that printer its maybe that was a problem for that. If they could not print at all after this solution just change your printerhead it is because that was the problem. If your printer are using the built-in printerheat from the cartridge just replace the cartridge of what color are did not print but if your using separate printerhead of your cartridge just only replace the printerhead only.
May 27, 2010 | Dell 926 All-In-One InkJet Printer
I have an HP Officejet 6300 all in one. The printer will disconnect and connect all on its own. I can have just printed something and try to print a second page and it will have disconnected. However, it...
Try resetting the printer using following steps:
1. When your printer is on, unplug the wire that goes to the computer.
2. Presee and release (#) and (*) buttons.
ou will see your display say "Support Menu"
3. Scrolls to the right until you see "resets" and pess ok
4. Select "semi-full reset" and hit OK
5. After printer turns off, turn it back on 30 seconds later.
Jun 01, 2017 | HP OfficeJet 6210 All-In-One InkJet...
How to fix 108 service printhead error on c762 lexmark printer
Hello, Please try this: Power off the printer, take the Color cartridge out(Magenta), take a thin and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. Try again to print this will help.
Mar 19, 2010 | Lexmark C762 Laser Printer
The toner light will not turn off, preventing printing. I'm perfectly happy with the print quality of my last printed page. Is there a way to force it off?
A small piece of electrical tape on the right and left sides of the toner cartridge covering the little round windows will fool the printer into thinking there is still toner and let you use it up.
Jan 08, 2010 | Brother HL-2040 Laser Printer
Printer wont turn on
for that problem may the printerhead have a problem may be your printerhead is overheated thats why you can't finish prinnting, try to pull out or remove the printer head and try to power on the printer if the printer is responced and power up again thats the time to change your printer head......
May 04, 2009 | Canon imagePROGRAF W6400 InkJet Printer
Printer not printing
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear access door. Press in the tab on the left of the door, and then pull out the door. Figure 1: Remove the rear access door c00861145.jpg
  3. Gently pull the paper out of the rollers. If printing labels, make sure that a label did not detach from the label sheet while passing through the printer.
  4. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water.
  5. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  6. Allow the rollers to dry completely.
  7. Replace the rear access door. Align the pegs on the right side of the door, and then push the door forward until it snaps into place. Figure 3: Replace the rear access door c00861146.jpg
  8. Reconnect the power cord to the back of the product.
  9. Press the Power button (c01345237.gif ) to turn on the product.
  10. Load paper in the paper tray.
  11. Try the print job again.
  12. With the product turned on, open the product cover. The carriage might move to the center of the product. Allow it to move to that position.
    1. c01553685.gif 1 - Print carriage
    2. Without turning off the product, disconnect the power cord from the back of the product. CAUTION: In the following steps, you move parts by hand. If you do not unplug the power cord, there is a risk of an electrical shock.
    3. Disconnect the power cord from the wall outlet.
    4. Make sure the print cartridges are secure, locked into the carriage, and have not come loose.
    5. Check for any obstructions under or around the carriage that are preventing it from moving.
    6. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right. Clear any obstructions.
    7. Close the product cover.
    9. Reconnect the power cord to the wall outlet.
    10. Press the Power button (c01345237.gif ) to turn on the product.
Jan 11, 2009 | Office Equipment & Supplies
Hp officejet 7110 All in one
The early signs of mechanical failure aka carriage stall. You can try resetting the print heads and cartridges and see if it helps.
Sep 17, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Printerhead
When the printhead moved left did it hit the left hand travel stop really hard? If so it's probably the same thing that happened to mine-a failure of a travel sensor, which is part of a circuit board. Turned out to be a repair shop job which took forever due to Canon's inability to provide spares for its products.
Aug 27, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Epson Stylus Photo R1800 InkJet Printer Logo
159 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
