I DON'T KNOW MIGHT WHAT HAVE HAPPENED BECAUSE THE ROUTER SWITCHES ON AND OFF AND WE KEEP HAVING TO RESET IT
Is it losing the signal, is that what you mean by on and off? Or is the power going on and off? Check ALL cables, reseat same. Does it do the same when plugged in using a Ethernet Cable? Contact your ISP to verify any troubles in your area and to verify the signal. It may be a outside equipment issue or your hardware , hard to say until you eliminate the possibilities one by one. ISP Modem, cables, Wireless device. If you are losing power check the AC jack in the wireless device, it often gets pulled by the cord breaking the connection inside the wireless device.
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
SOURCE: Obtaining the Encryption Code for my D-Link router
try logging on to your router's ip address (google search "[your router model] ip address"
after logging in (default username : admin, password: it is blank), look for the WEP key settings. it should show it there.
SOURCE: my d-link 2640t wireless router suddenly no Wi-Fi
This one can be one of two things.
If you have a digital multimeter, check the power connection and make sure that it's not to high (eg. 7.5 V DC should read no more than 7.8 V for it to work properly)
Otherwise, just reset the router. I have a feeling it is the first one.
Once it reaches to 130% above of what's rated, it can fry your network adapter in your computer and possibly more damage if it's wired.
SOURCE: unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
SOURCE: setting up secure wi-fi
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
When I try to start my treadmill which was working fine a couple of days ago, it displays LS and I can't get anything beyond that.
how to removal procedure of the cylinder head of car nissan 200SX when coolant leak
No electrical power in Kia Sedona 2007, won't turn over, won't lock,
95 Lincoln Chugs and Dies randomly it starts back up after a few minutes?
