Question about Panoview GrayWolf Fixed-Frame Screen Projector Screen
Wont roll up or down
I have the graywolf2 panoview projector screen & it has stopped working
Screen wont retract all the way up in ceiling
Assuming your screen a motorised type and is able to move down and up when you press the remote, it means that the motor is working well. 2 possible reason are:-
1), The limiter mechanism to stop the movement for the up and down position is faulty or misalign. Up limiter in this case require check and realignment.
2), The end of the screen ( the bottom ) while closing ( move up ) stopped too late, over shot and it fell down on the other side causing that extra length hanging. Up limiter in this case require check and realignment.
Pls contact your local Dalite support if you are unable to find a repair man.
Jan 20, 2011 | Da-Lite (84402) 133" 16:9 Projector Screen
Faint black bar rolling from the bottom
if the bar is black or purple you can try to use a ground lift plug and see if your having a grounding issue.
Jan 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
Hi! where can i purchase a 12 volt trigger cable for a motorized screen
Most projectors have a 1/8 inch (mono) or tip and sleeve female connector for screen trigger and output 12volts dc when the projector is powered up. So if the Optima screen has the optional trig in and it's 12 volts the cable is very easy to put together. Optima may have a cable available or you could spend just a few bucks at Radio Shack and your all set.
Oct 31, 2009 | Optoma Panoview Matte White Motorized...
When unit powers up - nothing shows - menu rolls
resit your projector to factory default. if problem occur clean the entire projector. or change your projection bulb.
Oct 07, 2009 | Christie LX45 Multimedia Projector
Screen won't stop rolling out
There is a rubber grommet on the left top of the projection screen, insert the supplied Allen key and turn anticlockwise and adjust turn by turn till the screen rolls out with just 2 to 3" of the black border shows on the top
May 16, 2009 | Draper Baronet 106 in. diag HDTV MW...
Rolling picture
Have you tested the source machine on another TV or projector. The picture might be rolling before it gets to the projector so you need to verify whether it is the source machine or the content then you might be able to determine if it is the actual projector. Sounds like the vertical sync has got lost somewhere.
Hope that helps. Also we can supply lamps for this model if you ever need.
Re your Sharp XV 9000S We are able to supply replacement lamp+housing delivered (excluding local your local taxes) for $US342 as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Regards Kevin Andreassend ICE AV Technology Ltd +64-9-414 2348
Jul 13, 2008 | SharpVision XV-Z9000U Multimedia Projector
CTX Panoview 630 Monitor
Panoview 630 Power Connector pinouts:
It has been many years since the question was posted but who knows, maybe this will help someone. Looking at the end of the connector clockwise from 1-oclock position:
5pm: no pin
shield is GND
(you can modify an Apple ADB cable to work)
Mar 15, 2007 | CTX Panoview 630 Monitor
Panoview GrayWolf Fixed-Frame Screen Projector Screen Logo
154 people viewed this question
Top Panoview Televison & Video Experts
Are you a Panoview Televison and Video Expert? Answer questions, earn points and help others
