LONG BEEP AND THEN PAUSE
I turn on my computer and I get a long beep and then pause, nothing else except the fan comes on. I believe the light in front is orange
Please help
Thanks
  • 271 Answers
I think the problem is with your RAM or display adapter. Try to remove your RAM and clean it with soft cloth and then try.
Thanks
Posted on Mar 07, 2009
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
What do the beeps codes i am getting mean? 1 short followed by 1 long.
Beep codes don't cause or signify damage, they are just telling you something is wrong. In your case, I would say the RAM is incorrectly seated or in the wrong slots.
2 beeps Memory (RAM) not detected
Remove the RAM and press it HARD until it locks in place. Do a visual check that the indent is against the mounting.
Computer POST and beep codeswww.computerhope.com/beep.htmHelp and support with troubleshooting computer beep codes and other POST related issues.
PC Hell: BIOS Error Beep Codeswww.pchell.com/hardware/beepcodes.shtmlPhoenix BIOS Beep Codes These audio codes are a little more detailed then the AMI codes. This BIOS emits three sets of beeps. For example, 1 -pause- 3 -pause 3 -pause.
beep codes Definition from PC Magazine Encyclopediawww.pcmag.com > Tips > EncyclopediaPC Magazine Tech Encyclopedia Index - Definitions on common technical and computer related terms.
How to Figure Out Why Your PC is Beeping (Beep Codes)pcsupport.about.com > Troubleshooting Guides > Symptoms2015-10-07 · Video embedded · How To Troubleshoot Beep Codes. Is Your Computer Beeping? Here's What to Do. By Tim Fisher. PC Support Expert Share Pin Tweet ...
Jan 23, 2016 | Computers & Internet
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
Ibm thinkpad a22m turns on, but no screen
diid u change memory or something it means that some hardware is not compatible or broken lik memory mostly it because of that
Feb 13, 2009 | IBM ThinkPad A21m 2628 Notebook
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
Computers & Internet Logo
David Payne
David Payne
