LONG BEEP THEN PAUSE WITH NO BOOTING!
My computer the other day when I turned it on made a long beep sound, I turned it off and then turned it on again and it booted. Now, I turn it on and it makes a LONG BEEP and then a PAUSE. I only get fans come on and nothing else, no video at all! I am using Windows XP pro
Please help thank you
  • 62 Answers
Reseat or replace memory
Posted on Mar 07, 2009
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
I'm trying to recover my system, but everytime I push F11 to get to the System Recovery Manager, I get a repeating Beep.
That sounds like it might be "POST" code beeping out at you. If it goes beep beep beep (pause) beep beep (pause), or something like that, etc.... then it is definitely a POST code. It can be anything from a bad or unseated video card, to a loose memory DIMM card.
The computer's BIOS chip is hardwired to a dedicated speaker, if something goes wrong (like your video card is roached), it beeps out a series of beeps (not unlike Morris code). Check the manufacture's website, see what BIOS your model is using (AMI, PHOENIX, ETC..), and then look up their website to interpret the code you are getting. The computer Mfg.'s manual might also have that BIOS POST code information in it too.
Please give more detailed information about the beeping sequence. Like, does it ONLY beep after pressing the F11 key once, or because your holding it down (keyboard buffer is full then). Are the beeps continuous, or are their pauses between beeps (if pauses, count number of beeps between pauses until it repeats, usually has a long pause before it repeats if BIOS POST CODE). Also, did something happen just prior to your computer going belly up, or did it just not want to turn on one day? Give as much information as possible (make, model, OS, etc) about your computer, and what its symptoms are. The more info I have, the better I can help you.
Jul 29, 2011 | Computers & Internet
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
Makes loud alarm sound when it is booting up and scrolls up on its own
Hello there lmitche4.
Here's your geek-steer ...
Is the sound you're describing a "beep"/tone? In all likelihood it's yes. At bootup, beeps codes occur if the motherboad/BIOS encounters any error during the POST (Power-On-Self-Test) sequence. Unless just one single beep (all is well), these beeps alert you about, and to the nature of, a problem in need investative/corrective actions on your part.
Refer here and/or here for an index of beep-codes, then determine which beep sequence you're hearing. You'll first need to know which BIOS you have installed. You can determine this quite easily by hitting the "Pause/Break" key on your keyboard in order to freeze the screen at the initial part of bootup when this info is typically displayed.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 10, 2009 | Acer Aspire One PC Notebook
When I go to turn on the computer, it just makes a beeping sound.
Beeping sound leting you something is wrong with some hardware. As for what,, listin to the beeps.. also depends on motherboard... here is a link http://www.pchell.com/hardware/beepcodes.shtml
But best way is to open up machine and make sure all the hardware is hooked up tight. If that does work look at the code list then go from there.
Sep 09, 2009 | Acer Aspire X3200 PC Desktop
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
Troubleshooting
are u getting any beep message ? let me know the model and the beep tone that you get, if you don't get any beep try changing ram if you have VGA card installed try changing that.
Dec 06, 2007 | Compaq Presario SR1000T (568657) PC...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
