Question about Sharp AR-5320 Black and White Copier
AR5316E error code h2
The display is flashing the code(h then 2) in the 3rd digit for sharp AR5316E
  • sherzadherki Mar 07, 2009
    Thank you too much you solved my problem
Hi in put # + inroput + c + intrupt + 14 + start
Posted on Mar 07, 2009
    Habit-Forming:
  • 41 Answers
Thermistor open detection
press:
# --> interrupt --> clear --> interrupt
14 --> start --> 1 --> start
Posted on Mar 12, 2013
My Sharp AR-M256 is displaying Code H2-00, how can i remove this?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 07, 2016 | Sharp Office Equipment & Supplies
Ar5316e h2 blinking on display
termistore error inpute simolasion 14 - 1
Jan 21, 2014 | Kyocera FS-6025MFP Laser Multifunction...
Display error H2
Gwnerally in sharp you cancel H2 doing a reset through code 14. did you do it yet?
Dec 03, 2011 | Office Equipment & Supplies
My copier machine sharp AR5316E shows error message 2U, please what is the solution?
remove the catridge to the machine and then insert it back. if it still display the same information the catridge might be damaged need to be replaced.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error f2 in sharp copier AR5316E
F2 sub code 00 - Toner Sensor problem, ID pattern reading error. You may have to replace the drum unit or have a tech clean the toner sensor
Mar 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
My ar5316e displays an h2 code and wont do anything, how can i fix this?
Press #, Interrupt, C, Interrupt keys in that order, display will go out. Enter 14,press Print key. If it doesn't go, replace thermistor.
Oct 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
What does it mean when h is flashing
There is a problem with the fuser unit , H2 means thermistor open or not connected, H4 means low temperature or fuser lamp not working. Reset with by pressing ; # , Interrupt , C , Interrupt. Display will go off then enter 14 and press Print key.
Jul 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR163 Displaying H2 error code
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
328 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
