Battery died and I charged it while still hooked up. Then starter didn't fire then it with clutch lever pulled in slightly. Then it died when throtte engaged to move foward. Both tclutch and throttle engaging may and sometimes nothing the engine just dies out.
SOURCE: after installing new fiber and steel plates (seven
Did you adjust the clutch cable? Have you replaced the springs in the clutch baskit with new one?
SOURCE: Clutch push rod will not depress to engage
go to this http://www.cmsnl.com/yamaha-rt1-19701971_model8356/partslist/A-09.html and then click on "view big image", this will give you a diagram of the clutch etc,, the adjustment (No. 26) may need looking at, or (No.11,12,) have broken.Basically you turn 26 in (clockwise) untill you feel light resistance then back off 1/2 turn (been years since i worked on one of these!) this should give you freeplay, have you just got the bike?, and do you think it has been stripped lately(ie the clutch). PS I am not affiliated with the web site i offered above, just a handy reference for you maybe? cheers
SOURCE: started bike, pulled clutch lever,
The clutch lever should have some tension, so could be a problem with the hydraulic actuator stuck, or a failure of the clutch. try bleeding the clutch, or pull the clutch cover off and see if the pressure plate moves
