Question about HP Compaq 6735s Notebook
Cannot get a wireless connection for internet
Shows that wireless and bluetooth are switched on but on my installation disc it says 'it cannot detect my router'
  • pontelemon
    pontelemon May 11, 2010
    Is it blue or orange light?
Bluetooth not detecting
Bluetooth radio is not "Enabled" in Device Manager. Turn it on.
Make sure is is detectable and Paired with the other device.
Jul 04, 2015 | Fujitsu LifeBook LH531 14 inch Notebook...
Bluetooth perephal device problem on dell inspirion
If you want to connect a Bluetooth peripheral device to a computer, you may need to download a new driver to support it.
There are two approaches to this:
If your Bluetooth device came with a driver on a disc, you can install the driver directly from the disc.
Otherwise, simply connect your computer to the Internet and connect your Bluetooth device to your computer, then wait for Windows to install any required drivers automatically.
You may receive this message when you connect your Bluetooth device to your computer: "Windows needs to install driver software for your Bluetooth peripheral device."
Bluetooth peripheral device driver downloads are easy to locate via any search engine.
Open the CD-ROM drive on the computer and insert the driver disc that shipped with the Bluetooth device.
Wait for a moment to see if the software auto-launches, as most modern software discs do.
If the program does not launch automatically, double-click the "My Computer" icon and then double-click the "CD-ROM drive" icon.
If this does not launch the software but instead opens a file folder, look for a .exe file such as "setup.exe" or "run.exe" and double-click that.
You're looking for a Bluetooth peripheral device driver.
Follow the on-screen prompts, once the software launches, to install the Bluetooth peripheral device drivers on the disc. You may be prompted to restart your computer at the end of the process.
Letting Windows Install the Driver
Make sure Windows is up to date, as most Bluetooth drivers are included in Windows Service Pack updates.
To do this, make sure your computer is connected to the Internet, then click the "Start" button in Windows and select "Windows Update" from the program list.
This will launch an Internet Explorer window. Click the "Find Updates" button in the window and wait for Microsoft to search for available updates.
If it recommends any high priority updates, follow the on-screen prompts to install them.
Connect the Bluetooth device to the computer.
There are three ways to do this.
If you have an internal Bluetooth receiver in your computer, just make sure the receiver and your Bluetooth device are turned on and put your device within range of the computer.
If you have a USB Bluetooth receiver, plug it into an available USB port on the computer; then turn on the Bluetooth device and put it within range of the computer.
If you have another type of auxiliary cable, you may also be able to use it to connect your Bluetooth device to the computer without using a Bluetooth connection.
Watch the system tray in the bottom right corner of Windows.
You should see a notification that Windows has detected a Bluetooth device, followed by another notification that the device has been installed properly.
The installation it is referring to is that of the driver. If this does not work as expected, proceed to the next step.
Click the "Start" button in Windows, then click "Control Panel." Launch "Device Manager."
Expand the "Bluetooth Devices" entry in the Device Manager by clicking the plus sign next to it.
Find your Bluetooth device listed under this heading, right-click it and select "Update driver" from the list of options.
Wait as Windows automatically finds and configures any missing Bluetooth peripheral device driver downloads.
Hope this helps
Nov 06, 2012 | Dell Inspiron 15R 5520 USB Docking Station...
I installed the Asus mini Bluetooth USB - BT211 and I see the icon Local Area Connection - A network cable is unplugged . When I go to the Bluetooth Suit and click on the configuration task that IE fails...
bluetooth does not connect to the internet, it connects to other bluetooth devices such as bluetooth mobile phones.
the network cable shows unplugged if there is no cable plugged into it and going into your internet router
Apr 09, 2011 | ASUS USB-BT211 Mini Bluetooth Dongle -...
Just installed Netgear511B. It shows I'm connected
i would go into internet options in explorer and go to connections, then lan settings.verify that auto detect settings is checked, then click ok. restart pc and try ie.
Apr 30, 2010 | NetGear RangeMax NEXT WN511B...
Bluetooth problem in lenovo 3000 G430 laptop
i am using lenovo 3000 g430, and i am fall in problem about bluetooth,
i am already install xp and vista, but when i install the bluetooth driver
one warning message show me "bluetooth device not detected"
my bluetooth device switch is on but indicator led light still off,
please help me , how can i use bluetooth in this laptop.
Dec 13, 2009 | Lenovo 3000 Y410 Notebook
HOW DO YOU TURN BLUETOOTH ON
Check the BIOS to ensure the wireless card is detected. Also verify the Wireless setting is turned on and not set to Always Off.
If the Bluetooth device is installed, also verify the radio LED is enabled. You can turn the wireless and Bluetooth cards on or off with the wireless switch.
If the card does not show up in the BIOS or Device Manager, try reseating the card.
Oct 06, 2009 | Dell Inspiron 1525 Notebook
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
My toshiba satellite x205-s9349 cannot connect to internet
Despite wireless connections being susceptible to EMI, bluetooth signals do not tend cause the kind of interference that would prevent you from picking up a wifi signal. You say the wifi switch is on, but the bulb is red. (It is supposed to be red, that indicates its powered on). The things to check are to see if you are detecting the wireless signal, are you inputting the proper protocols for any known established wireless Security (WEP/WPA). Are you using a wired connection to get on the internet or another computer/location?
Dec 15, 2008 | Toshiba Satellite X205-S9349 Notebook
Bluetooth
I am having ACer 5500 Lapto Computer. I format my system and i installed XP professional. i installed all the driver softwares but the bluetooth device is not detecting, it show there is no bluetooth device check the device. How should i rectify the problem please help me. 5500 is consists internal Bluetooth.
Nov 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
HP Compaq 6735s Notebook Logo
160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
