Steiner M/M 7x35, flat, old model
Problem for Steiner M/M 7x35, flat, old model (Pre 1992)
Binoculars?
By Charlie - usenet poster
Is it worthwhile adding binoculars to a bug out bag? If so, what should
I look for in a set? Magnifying power? Light-gathering ability? Something
else?
Mike S. Medintz | Another redneck for Wilderness
"Wise Use" isn't. |"If you don't vote, don't bitch."
Solution #1
posted on Aug 02, 2007
Not Rated)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
We were just talking about this the other day, what with the
increasing use of lasers in the field. A friend of mine who
tries to keep up with weapons development and research was
telling me that there had been an idea of using lasers to detect
optics (from the reflection, I guess) and once detected of
specifically targeting the optic with a high intensity burst to
destroy its usefulness. Obviously, since a good bit of the optics
in use will have an eyeball peering through it, this could be
very detrimental to your continued use of vision. It seems to me
that if this was intentionally used as a weapon it would
contravene the Hague convention. Not that it would stop it from
being used, of course. That filter that you speak of above leads
me to believe that it's a thought that's occurred to others as
well.
If anyone out there has any info about such a filter, where
they can be procured from or how to manufacture one I'm sure
there's quite a few here who'd like to know. Thanks.
Oh yes, some form of magnifying optics is *very* useful.
Even a cheap pair of Tasco's beats the mk1 eyeball for those far
off things needing looked at. If you can afford the German
optics they're very good, but a pair of Tasco or Bushnell binocs
will cause much less anxiety as they knock around in the glove
box.
Alan.
Fron the House at Cat's Green. Alan T. Hagan
Semper peratus
The Universe is utterly indifferent to the fact that you
do not realize the consequences of your actions, you will
have to deal with them all the same.
E-mail c/o
Was this helpful?
Yes
No
Solution #2
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
(Mike S. Medintz) wrote:
I have a pair of the very compact Simmons 8 x 21 binoculars in my bag.
I thought about this when I first put my kit together and still keep
them there. The larger bino's are just too heavy and clumsy to use.
Remember, my kits are all based upon the presumption that I will have
to walk out of any situation. In my two Broncos, I do have a pair of
Zeiss bino's (older ones, work great) and in my own I have a pair of
the Steiner's. But I wouldn't want to add the weight to my back for
either of these.
Geoffrey L. Hardin
"You got more money than sense!" - Mrs. Hardin
Was this helpful?
Yes
No
Solution #3
Not Rated)
Riddle
Rank: Apprentice
Rating: 0%, 0 votes
Richard A. De Castro < : (Mike S. Medintz) writes:
: I carry a set. I have the Steiner's, the same ones as the US Army has.
: Very durable, incredibly expensive, not too heavy.
I concur on the Steiner 7x50mms: great glasses. Unfortunately the Army's
decided to drop them (cost I believe) and has adopted the Fujinon 7x50mm
binos. _Also_ as the M22, so trying to keep the two variants straight
when ordering repair parts and such has become real fun.
The Fujinon (US-made by the way) M22s aren't nearly as good as the
Steiner M22s in my experience.
GI binos have a filter fitted over the objective lenses to protect the
user against eye injuries from lasers (range finders and such). I had
the chance to ask a rep from the manufacturer of the filters about a
civilian source for these a few years back, and he claimed they were
classified and military-only. Maybe, I dunno... Anyone have any better
info than that? (The filter looks to be an integral part of the Fujinon
M22, but it's a slip-on unit, with a dab of glue to keep it in place, on
the Steiners.)
: In general, powers over 7 or 8 are too hard to hold steady, leading to
: rapid eye fatigue. For daylight use, an objective diameter of about 35mm
: is fine (hence the designation 7x35), for night use the objective diameter
: should be closer to 50 mm (leading to a ratio of between 1:5 and 1:8).
: The larger the objective diameter, the greater the light gathering ability.
: It's really noticable at twilight, as it makes it easy to see things that
: would be shadows otherwise. The down side of very large objectives is that
: they let too much light in during the day, causing eye strain.
: In general, the quality of a pair of binoculars is something you don't
: realize, until you've used a very fine pair. You might think your
: tasco's or bushnells are fine, and they're certainly inexpensive. But, you
: will notice the difference the first time you use a good pair.
: Other fine brand names are Swarovski, Nikon and to a lesser extent, pentax.
: Problems with the cheaper brands are loss of colimation (the two barrels
: are not optically parallel to each other), fogging, and flare from poor
: coatings on the glass surfaces. While the military uses 7x50's, Steiner
: also makes them in 7x35, with the rubber armor (good for a little protection,
: and easy to hold), and larger 8x and 10x versions, with and without
: compasses, optical rangefinders, etc. Even Steiners cheap models (the
: Pilot line) is good - better than the bushnells at about the same price).
The Steiners _used_ to be affordable a few years back; I think I paid
$220 for mine in '88 or '89, and a friend picked up a pair while in Saudi
Arabia for $180 or so during the war (_legitimately_ picked 'em up even).
Currently the 7x50mm GI-pattern ("Military & Marine") Steiners are running
about $490 or worse, but there's a place advertising "Factory
Refurbished" with "5 Year warranty" Steiners for $300 (SWFA, Inc,
214-223-0500). The Fujinon Polaris 7x50mm binos are $590 from the same
place.
Do you _need_ binoculars? Well, people are visually oriented animals: we
do a lot better when we can see what we're dealing with. It's hard to
imagine any situation where you wouldn't be better off/safer taking a
good long look _before_ you take any action. I carry mine at all times;
when I respond to a situation it's a great comfort to be able to see if
there's a HazMat placard on the truck, or if someone's obviously armed,
or if the smoke I think I'm seeing is just dust or haze...
Arne Gustav Carlsten
Flagstaff, Arizona
Chomh da/na le muc...
Was this helpful?
Yes
No
Solution #4
Not Rated)
Janice
Rank: Apprentice
Rating: 0%, 0 votes
Mike I have a pair of the small Nikon binoculars which I keep on hand.
They come in several powers and provide excellent clarity. Mine came
in a small padded case for protection. I have even stopped taking my
larger and more powerful binoculars hunting in favor of these.
Compact, lightweight, and a definite plus for your bag.
Frugal
Was this helpful?
Yes
No
Solution #5
Not Rated)
Kim1
Rank: Apprentice
Rating: 0%, 0 votes
I guess I've never thought about it, good topic. I have at least a four
power scope on nearly every rifle I own, so I do have some form of
bringing in distant objects, but that wouldn't exactly be a good idea if
I was trying to keep an eye on a family member from a distance. My
favorite item is a compact 30 power spotting scope that I've mounted a
small photography tripod on. I've found the "rubber armored" binoculars
and spotting scopes tend to take quite a bit of abuse, so that's what I
own.
While I probably won't add them to my 72 hour kit (which is mostly for
natural disaster evacuation), I may just toss the pair of super cheap 7
power compact binocs I've got into the glovebox of my Blazer.
Good idea Mike.
Thanks,
Mark
I went to the woods because I wished to live deliberately... HDT
Was this helpful?
Yes
No
Solution #6
Not Rated)
Gary10
Rank: Apprentice
Rating: 0%, 0 votes
Warning: I am a trained professional. No, Really!
Rick N6RCX NREMT ATP MA Do Not try this yourself - it could get ugly
Richard A. De Castro - To those who have defended it, Freedom has a flavor
the Protected will never enjoy.
-Don't Tread On Me!- =Don't Forget to Vote!=
Was this helpful?
Yes
No
Popular Solutions for Steiner M/M 7x35, flat, old
Questions and Unsolved Problems for Steiner M/M 7x35, flat, old
Do you recommend Steiner M/M 7x35, flat, old model (Pre 1992)?
Answer
Answer
one arm is loose; how do I tighten it?
Answer
Needs to be openened, cleaned, and lubricated. I had this done about 10 years ago and the company... (More)
Answer
I have a pair of 25x100 Orion binoculars. The metal bridge is broken. Is it possible to repair this.
Answer
Steiner yard tractor won't start. Battery has charge, oil light comes on, starter has been bench... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Steiner M/M 7x35, flat, old...:
Top Binoculars Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Binoculars Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
