Question about Zoom Wireless-G 4410 (44100000) 802.11g/b
I have the zoom wireless g router adapter. I am running on xp service pack 2 and want to connect an extra computer with the usb to my network. The software picks up my router connects then every to to three seconds turns to 'try to authenticate'so i know the connection is getting through i just cant get it to stay!! any ideas?
  • 135 Answers
*Check the advance settings of the router:
Turn the MAC filtering off
Disable the wifi-protected setup
*For the computer settings:
Disable the IEEE of the wireless adapter.
- Reconnect to the network again.
Note: Just make sure that the driver and adapter are installed properly.
Posted on Mar 09, 2009
System: Microsoft Windows XP, Prof v 2002, service pack 3 Dell computer: Intel(R) Pentium (R) M; Processor 1.60 GHZ; 988 MHZ, 2.00 GB Ram Cannot connect to internet using Belkin play wireless USB adapter...
1. You have to have access to a wireless router to be able to connect.You also have to be allowed to connect.
2. A wireless adapter will show all computers in the area wirelessy but if you don't have a key to access you will not be able to connect.
Jul 14, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
No matter what i do and what settings i try my nice brand new WNDA3100 wont even aquire a network address. Connecting with or without security doesn't make a lick of difference it just times out...
Have you tried going to your WIRELESS CONNECTIONS, clicking PROPERTIES, the Click Authentication, then clear the Enable IEEE 802.1x authentication for this network check box. If it's not checked then it isn't being used. This can be a problem for those running XP with service pack one. You can also resolve the issue by getting service pack 2.
If that isn't your situation (ie you don't have xp with service pack 1) does it behave this way when the computer is sitting in the same room as the wireless router? Do other wireless machines you use connect to the router? Did you use netgear's utilities to set up your wireless network or the one in windows? Sometimes that can make all the difference.
If it works in the same room by not in another room it could be the antenna or something blocking the signal between the router and the machine such as a furnace.
If you set it up using netgear's utilities and it is functioning intermittantly (and you're sure the network set up is correct because sometimes you can get online) then it is possible the adapter itself has a problem. If it's new you can return it.
Also make sure you are using the correct GATEWAY, which would be the ip number of your router. It could be that you're picking up a weak signal from a nearby neighbor.
Feb 10, 2011 | NetGear RangeMax Dual-Band Wireless-N USB...
Can not connect to Verizon MiFi2200 wireless network
Yes the verizon tech informed you right that the ip address will be acquired by your wireless adapter automatically. However there are lots of reason that your adapter not able to connect wireless.
1. Make sure no firewall or antivirus is blocking your wireless connection to connect wirelessly.
2. Make sure you are entering the right password for the wireless network if your network is secured.
3. Make sure the wireless adapter driver installed properly.
4. You can also try to restart the DHCP services through which your computer will try to get the ip address. I am giving you the steps how to restart the DHCP service once again.
- Click on start
- Under start search or under run type in services.msc
- Search for DHCP client and right click on that and you can click on restart. It will restart your services.
5. Make sure other computer are able to connect wirelessly to identify whether there is a problem with the router or a wireless adapter.
6. Make sure the wireless channel on the router is correct sometime due to wireless channel your computer not connect.
I hope this will help to resolve your concern. Still if you face any problem let me know.
Thanks & Regards
Jazz
Jun 27, 2010 | Linksys Ultra RangePlus Dual-Band...
My wireless adaptor can not find my wireless router
Please check tour wireless adapter if its working and properly installed in your computer. Here's how to do it;
Checking Device Status on the Device Manager
For Windows 2000 or XP:
1. Click on Start, go to Settings and then Control Panel.
2. Click on System, go to Hardware and then Device Manager.
3. Click the (+) sign on Network Adapters and select the adapter.
4. Double click on it and read the Device Status.
If your wireless adapter is not working and installed properly, you have to re-install the wireless adapter software driver. When the wireless adapter is already properly installed you can follow this steps below;
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 10, 2009 | NetGear WGR614 Wireless Router
Wired internet working through netgear... wireless access denied
You must determine the wireless security of your router;
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
a. Click on the Wireless Settings under Setup.
b. take note of the SSID
c. if your using WEP...the network key would be on the key 1.
d. If WPA-PSK TKIP is in use just type in a new key with a minimum of 8 characters on the passphrase box. Please remember it.
Apr 06, 2009 | NetGear WGR614 54Mbps Wireless Router...
Netgear Wireless USB 2.0 adaptor cannot find a signal
Before doing that, make sure your wi-fi is turned on in your router. If the adapter is not seeing a signal, it may well be that your router is not broadcasting one. If you have another computer with wi-fi (like a notebook), or know someone who does, you can always use it (or theirs) to see if they can "see" the router via wi-fi, which will tell you if the problem is router or adapter.
Cheers
Nov 10, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I cannot connect my netgearWG111T wireless usb adaptor to my router
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Connecting to the Wireless Network
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Nov 08, 2008 | NetGear WG111T 802.11g/b (E82321) Wireless...
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
Power
1.
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
efefddd.jpg Next, connect your router to your modem:
If you currently have your computer connected directly to your modem: Unplug the network cable from the back of your computer, and plug it into the port labeled Internet, WAN, or WLAN on the back of your router.
If you do not currently have a computer connected to the Internet: Plug one end of a network cable (included with your router) into your modem, and plug the other end of the network cable into the Internet, WAN, or WLAN port on your wireless router.
If you currently have your computer connected to a router: Unplug the network cable connected to the Internet, WAN, or WLAN port from your current router, and plug this end of the cable into the Internet, WAN, or WLAN port on your wireless router. Then, unplug any other network cables, and plug them into the available ports on your wireless router. You no longer need your original router, because your new wireless router replaces it.
5641429.jpg Next, plug in and turn on your cable or DSL modem. Wait a few minutes to give it time to connect to the Internet, and then plug in and turn on your wireless router. After a minute, the Internet, WAN, or WLAN light on your wireless router should light up, indicating that it has successfully connected to your modem.
3.
8d8f1b2.jpg Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.
Next, open Internet Explorer and type in the address to configure your router.
You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacturers.
Router Address Username Password 3Com
http://192.168.1.1
admin
admin
D-Link
http://192.168.0.1
admin
ts.gif Linksys
http://192.168.1.1
admin
admin
Microsoft Broadband
http://192.168.2.1
admin
admin
Netgear
http://192.168.0.1
admin
password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three things:
1.
Your wireless network name, known as the SSID. This name identifies your network. You should choose something unique that none of your neighbors will be using.
2.
Wireless encryption (WEP) or Wi-Fi Protected Access (WPA), which help protect your wireless network. For most routers, you will provide a passphrase that your router uses to generate several keys. Make sure your passphrase is unique and long (you don't need to memorize it).
3.
Your administrative password, which controls your wireless network. Just like any other password, it should not be a word that you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings.
The exact steps you follow to configure these settings will vary depending on the type of router you have. After each configuration setting, be sure to click Save Settings, Apply, or OK to save your changes.
Now, you should disconnect the network cable from your computer.
4.
5118333.gif Follow these steps to connect your computer to your wireless network:
1.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.5914228.gif 3.
4.
Jul 03, 2008 | Acer Aspire 5100 Notebook
Zoom Wireless-G 4410 (44100000) 802.11g/b Logo
153 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
