Question about Nokia N95 Cellular Phone
WATER DAMAGE N95 EVERYTHING IS WORKING EXECPT THE SCREEN SCREEN GONE VERY DIM
  • bigwigkits Mar 07, 2009
    i have the same issue. mine was ok after i left it for 2 days to dry out. screen had lines across but was functioning. Now it is lighting up but with no graphics! So i can hear texts but not view them. Very annoying as i am not due an upgrade until november and not insured either.
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
My iphone got wet now light is so dim i restored it and everything but it is still dim i can do call and receive calls everything else works great execpt for the light what can i do.
First, check your brightness setting. Usually I'd give some other troubleshooting tips, however the fact that the phone got wet tells me that the screen itself has water damage. A good trick (something I've done many times) is crack the screen then take it to the Apple store and ask for a replacement. They have a "One-time exception" and will replace the phone for free. Hope this suggestion helps :)
Aug 18, 2011 | Apple iPhone Smartphone
PLEASE HELP!!! I have black screen on my nokia n95 and everything is working just screen doesn't... What i need to do? I tried to take out my battery, but it still doesn't work. Please, do you know what...
This is a problem that is associated with the flex cable.
The cable might be broken or damaged someway. You have to see a repairer because replacing this cable requires enough expertise and care.
It is advised to be done by an expert.
Hope this was helpful?
Feb 12, 2011 | Nokia N95 Cellular Phone
When i plug the charger in my Nokia N95, the white (screen is dim) startup screen with the word "Nokia" will appear, then after about 5 seconds the screen will go black and will not charge. This has...
you bought a fake battery or the battery terminal are bad and are having poor contact with the battery.remove the battery and try to clean the three golden panels that come in contact with the battery
Sep 23, 2010 | Nokia N95 Cellular Phone
My n95 is having some display light fading problem. i cant see anything. but when i am restarting i can see the nokia symbol very clearly. after that everything fades
Hello, problem can be caused by, light IC inside the phone , or the screen is getting damaged and will need to be replaced.
Replace screen with another first to see if the light problem will stop, before you check the light IC .
Take care.
Jun 21, 2010 | Nokia N95 Cellular Phone
Dell inspirion 2200 notebook screen really dim cant see hooked up another monitor and it works . how can i fix?
If your screen is dim but still displays everything then please check if the screen's brightness has not been accidentally reduced. If that is okay, then you have a damaged screen inverter and it needs to be changed. If the screen does not display at all, then you may have to change your screen.
All the best.
Jan 19, 2010 | Dell Inspiron 2200 Notebook
Screen has gone blank after getting wet. Green and red keys still light up but nothing else is working. Would a replacement screen fix this ?
The only thing you can do is to try & dry it out.
Remove the battery panel and battery.
Wipe inside battery compartment and battery with kitchen towel, then move all pieces to a warm room(not on radiator) and leave for 24 hrs.
Then fix in battery and battery panel.Turn on ,that will be the best as you can get this phone.
As water damage affects the whol phone.
Fingers crossed for you.
Dec 01, 2009 | Nokia N95 Cellular Phone
Change lightbubl V557
I am sorry to say that it is not a lightbulb. It is a LED screen you have blown a circuit not a bulb. You can replace the screen, but it is not cost effictient. You are lucky the phone works at all. You must have done the smart thing and took the battery out. If you did, good job, smart thinking.. Sorry my friend..
Please give good ratings, they are really important to me
Aug 04, 2009 | Motorola Cell Phones
Water Damage - Nokia N95
Can you open your n95 by yourself? if yes, detached the LCD then cleand its LCD connector by alighter fluid using a small brush..thank you..
Feb 05, 2009 | Nokia N95 Cellular Phone
Nokia n95 keypad light is not working...
hello..
the problem is the water damage mate... cut your loses and get a new one.. spending any money on this will be a waste..
Nov 29, 2008 | Nokia N95 Cellular Phone
Nokia n95 8gb
i think after all that you should replaced the mainboard
Oct 20, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
