Crease reduction facility won't work
I have a Hotpoint Aquarious WF640 super silent washing machine. I want to use the crease reduction facility. When a wash programme is selected the crease reduction facility does not work. How do I use this option?
    Problem Solver:
  • 6 Answers
Crease reduction facility is just a slower spin cycle if you coose a delicate wash there will be no apparent difference
Posted on Mar 07, 2009
Hotpoint aquarious 1200, not completing a washing cycle
where does it come to a stop
five mins in to progam or at rinse
Jan 13, 2014 | Washing Machines
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Oct 21, 2012 | Hotpoint Washing Machines
Hi : Problem with my Hotpoint WF640, Aquarious
Tools you will need:
2 Adjustable wrench's which opens up to 1"
Flat head screw driver
Philip screwdriver
Pliers
I need clarrification on which connection is leaking after the plumber replaced the new taps, but for now I will presume he replaced the isolator valves on the water lines to you washing machine.
To fix the leaky pipe open one wrench so that it fits snugly around the valve body (you may want to remove the little plastic handle of the valve) set teh other spanner on the nut which holds the pipe into the valve and rotate it in a clockwise direction to tighten, if the leak persists tunr of the water and check:
1. that there is an olive (little brass ring under the nut that the nut can tighten down onto.
2. PTFE tape or putty on the threads of the valve
As for the leak on your machine this leak could be coming from anywere, the usual suspects are:
Door seal
Drum outlet
Pump assembly
Detergent Drawer
Dissconnet the power and have a look for were you see the leak, look out for limescale, rust and other water/detergent marks to help you identify were the leak is comming from. Usually you can access the back of the machine and with a torch should see the pump assembly, you can remove the top of the machine usually 3 philips screws anlong the back side of top cover then it just lifts off.
Aternativly with some help you can lean the machine backwards so that you can look under it. ONLY attempt that if you have help and you can securely hold the machine in place. Lying it down flat might damage the machine if you dont do it slowly and very carfully, if you have the original shipping bolts that came with the machine I would advise installing them to help hold the drum in place.
Hope this helps.
Jun 23, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarious extra wd63 motor mounting broken
Made a new mounting bracket out of a piece of flat bar. Machine has never run so quietly!
Jun 13, 2009 | Washing Machines
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
I have had aqarius a hotpoint aqarius 1000 wm62p
It has a wide variety of wash programmes for white cotton, colourfast cotton, polyester, non-colourfast cotton, wool blends and wool itself. These standard programmes take from an hour and a quarter to three-quarters of an hour to complete.
There is also a quick wash programme lasting just under half an hour for lightly soiled items and a pre wash soak for heavily soiled items. The machine has four buttons providing extra facilities that can be set independently of the main wash programmes to give you a more comprehensive range of settings.
There is a rinse hold button, which I find extremely useful. When set this holds the clothes in the final rinse water until you are ready to unload the machine. You then release the button, let the machine go through the final spin and then you can unload the machine. It means that you don’t leave damp washing in the machine for the time between the cycle finishing and you unloading the machine, which would make for very creased clothes. There is also a button to depress if you want to use the super rinse facility. This merely increases the volume of water in each rinse so that the clothes are rinsed more fully. I have never used this particular facility, as the ordinary rinses are fine for my needs.
The next button allows for a slow spin. I find that this one is really useful for the items that I need to iron as it means that they don’t come out of the washing machine as creased as they normally would on a faster spin. The only problem with this is of course that the clothes are not as dry as they would otherwise have been. The final button is used to set the economy wash feature. This means that the washing machine’s own heating system is not used and the wash is done with the water at the temperature entering the machine from your hot and cold water tanks. This of course means a cooler wash so it’s only suitable for lightly soiled items.
The door remains locked during the wash programmes so that it cannot be opened accidentally and it can be locked when not in use too if you have small children who might get into mischief! The other big selling point for this particular model is that it gauges the size of the load and uses the correct amount of water needed eliminating the need for the half-wash programme. This also means that it is both water and energy efficient
Mar 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
