Question about Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV
Part number for mirror in Sony KDP-51WS655
I recently bought a Sony KDP-51WS655 and, sadly, on the way home, it tipped over in the back of my truck and the  large front surface mirror inside was shattered. I am looking to find a replacement mirror,  but I need to know the part number so I can purchase the correct part.  I could not find a service manual.   Could someone please help me find the part number and/or service manual?
Thanks!
Jordan
  • 294 Answers
Sony Part Number: 2-023-094-01 I WENT TO A WEB SIGHT CALLED WWW.PARTSTORE.COM U MAY WANT TO GO THERE AND MAKE SURE ITS WHAT YOUR LOOKING FOR IT SAID A MIRROR (51)
Posted on Mar 07, 2009
  • JEFFrey BAKER
    JEFFrey BAKER Mar 07, 2009
Where the g board located on sony kdp-51ws655?
Sep 14, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
KDP-51WS655 OR KDP-57WS655 57 inch HD PROJECTION TV SONY Problem: I have to remove the plug from wall outlet and push it back in a few times in order for the TV to actually turn on. Otherwise the power...
check the power switch for dry joints and resolder all joints if it still doesnt work check power board for dry joints as this is a common problem let me know how u go
May 28, 2010 | Sony KP-57WS520 57" Rear Projection...
Sony KDP-51WS6755 not turning on, power surge, pop, 6 blinks.
unplug it immediately. never tolerate a sizzle (frying noise) or a popping noise. do NOT replug. fire hazard.
contact serviceman for repairs. Sears Home Service can handle this for you.
Apr 14, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
My sony kdp-51ws550 turns on and then dies in seconds. what is wrong with it??
most likely bulb is going bad and internals are dusty helping overheat the already used bulb.
Apr 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
Oct 26, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony KDP-51WS655
how many times does the light blink?
Feb 19, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony KDP-51WS655 Need part and info
The cn6001 part number is 1-580-843-11
The Diode part number is 8-719-843-11 (both diodes are the same)
Oct 31, 2007 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV Logo
157 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
