Question about Epson LQ-2180 Dot Matrix Printer
Printing problem I have epson lq-2180 printer with the following problem:The pause light is continously on and am unble to print. when i try to print nothing is happeninig.
Sir, we have a problem to install a printer that "printer driver cannot be installed. your computer system may be in an abnormal condition. please exit window and try again". how to solve this problem.
Posted on Apr 10, 2009
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 continuous printing problem
The default paper height is 12". If you want to change it to 11" you should refer to printer manual and follow the steps. Otherwise if you are using a software for printing. Ask your developer to give following command for setting paper height
Chr(27) + Chr(67) + Chr(0) + Chr(11)
Mar 09, 2010 | Epson LQ-2180 Dot Matrix Printer
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Jan 09, 2009 | Epson LQ-2180 Dot Matrix Printer
Page setup
see the paper length you are using
ex. 8.5 X 12 "
set the paper length programatically by using following command
?? chr(27)+chr(67)+chr(0)+chr(12)
Jan 09, 2009 | Epson LQ-2180 Matrix Printer
The pause light continous blinkiing
plz check the ink status and check is there any paper jam
Nov 01, 2008 | Epson LQ-2180 Dot Matrix Printer
Unable to print
plz check the ink status and any paper jam
Jul 08, 2008 | Epson LQ-2180 Matrix Printer
Lq-2180 continous blinking
Please read through these instructions first and then follow the steps below:
1. Please power the printer OFF.
2. Remove the printer cable from the back of the printer and remove all the paper as well.
3. Hold down the "FONT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "FONT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer OFF.
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
If the situation persists, remove the ribbon and paper and slide the print head back and forth so that it makes contact on both sides forcefully enough to make a loud noise. Reload the ribbon and the paper and try your test again.
Dec 07, 2007 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
611 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
