Question about LG Washing Machines
My washing maching is fashing LE. I'm unsure as to what the problem is.
  • kackermann Mar 07, 2009
    Turned out to be a communication problem. I unplugged the machine for 20minutes to reset it and turned it back on and now it is working!
    Problem Solver:
  • 6 Answers
Pump filter blockage. release blockage and reset
Posted on Mar 07, 2009
Samsung washing maching J843, 7 Kg front load - shows error "LE" and stops working
Sorry, I do not know your particular machine but there are 2 possibilities for 'LE'. One is a drain error. The other is a Lock Error indicating there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention however ---->
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 09, 2011 | Samsung Washing Machines
I just "inherited" a maytag neptune front load
http://www.kitchenaid.ca/assets/pdfs/literature/2206687.PDF
http://www.kitchenaid.ca/assets/pdfs/literature/6_2727060.PDF
Oct 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Nec nw-452 washing maching gives le message after filling with water? any help?
The lid switch is faulty and needs to be replaced or bypassed.
Sep 28, 2010 | Washing Machines
Won't start keeps fashing door on screen
Hi
The door lock may be jammed kindly switch off the unit and check whether you are able to open the door after 3-5 mins if you are unable to open the door means the door lock switch is defective kindly change the door lock switch
May 18, 2010 | Washing Machines
Bought second hand machine. works well,however makes noise from underside machine while in operation. and bangs signifigantly when it shuts down. It's a whirlpool unit. unsure of model number. about 3/4...
This sounds like the brake is engaging to stop it from spinning. You can find the model number under the lid at the rear of the lit on the maching. I am assuming this is a top load model.
Jan 04, 2010 | Whirlpool Washing Machines
Hotpoint First Edition washing maching won't spin
hello any spin problems could be down to the module circuit board
shaun
Aug 02, 2009 | Washing Machines
Ladki nahi fash rhai hi
apni didi ko fasa le.ghar main raat ko sath soyr gi,,,,
Apr 04, 2009 | Microsoft Windows XP Professional
Le son pour pc compaq evo
Dear sir..,please help me to solve my soundlost problem.I can have image but can't hear any sound
Jan 17, 2009 | Compaq Audio card Sound Card
Changing a Whirlpool Washing Machine Control Panel
youll be able to uninstall all the knobs(screws behind the knobs), then take off the switches from the panel without really needing to take wires off the individual switch.the timer is a tricky knob to remove (there is directions printed in the palstic housing of the timer back itself explaining how to release the kob
Nov 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
