Question about Miele WT945 Front Load Washer / Dryer
Machine has stopped mid-wash. End of cycle alarm is sounding and a red warning light (Inlet/Drain) on bottom right of control panel is flashing. What actions must I take. Regards Tony Newman
    Sergeant:
    Champion:
  • 245 Answers
Go in touch with the store u bought the washing machine or go in contact with MIELE///
GOOD LUCK SHOULD NOT BE A BIG PROB TO FIX IT
Posted on Mar 07, 2009
How can I stop the lights from flashing mid cycle and make the machine continue its cycle to the end and drain?
first you need to take off the drain hose that allows the water to pump out and check to see if it is blocked at the part that it connects to from the machine , you could try to blow back the water but if its blocked i doubt it , after you remove the hosing inspect the inside of where it fitted onto , with the cord unplugged from the wall you might be able to use a bit of wire with a tiny hook bent onto it and pull out any blockages . also make sure the water pump is engaging when it goes into the pump cycle .
Aug 07, 2017 | Washing Machines
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Hotpoint wma62 normal sign lashing red green sign flashing machine will not start what is the solution ?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 05, 2012 | Hotpoint Washing Machines
Samsung washing machine wf7604naw door is stuck and the lock sign won't go away- how do i force the door to open- my cloths are locked inside
It can be the door lock servo which is a ****** to reach or tamper with as it's a sealed unit, I sorted mine by draining via the filter port at the bottom right front behind the rectangular front panel ( this will normally fill a small saucepan half way when machine is level which is the best way to drain although you will be using a cellulose sponge to soak the water from the floor rather than directly into the pan) then tilting from the front 45 degrees or more backwards. This all being done with power off and water inlet pipe disconnected as this can and will snap readily. Having rested back down to a level try the door again and smile.
Apr 30, 2012 | Samsung Washing Machines
Washer stopping after filling,wont complete any of the programmes, emptying and filling ok,recently replaced pump and programme selector.stain vanish light flashes and top of panel for time to end light...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 23, 2011 | Washing Machines
The wash cycle is taking a lot longer to do, for example the 30 min wash is taking 1 hour and sometimes longer, the motor seems fine, could it have something to do with the pump
Hi.
When the cycle hangs it means that because of a fault the conditions to advance are not met.
If the washer hangs at start (filling), then there is either a problem with water pressure, blocked inlet, or water flowing back from drain hose because of incorrect hose settings (called siphoning).
If machine hangs mid cycle, then it is often a temperature related problem. Check thermostat and element or check hot inlet and thermostat if dual inlet. Testing requires disassembling and use of the multimeter.
If machine hangs mid cycle or end of the cycle (before spin), then it can be drain system. Check drain hose, drain filter attached to pump and check the pressure switch.
Most machines have a service sheet hidden inside the control panel assembly. The tech sheets shows how to run a diagnostic cycle that will tell where the problem is.
Most common faults resulting in long cycle are heat-related and drain problems.
Regards.
Ginko
Jul 17, 2011 | Samsung Washing Machines
When i turn the dishwasher on it start but when it whant's to wash the two red lights goes on and machine beep and stop washing.
After the intital cycle of the water inlet vavle opening the program shifts to the next mode But since there is errors on the controller the machine shuts off with an alarm.
Now check the front door opening switches, check the washer pumps, check the drain cycle/pump.
remove and check the door switch contacts, the pump and the drain.
Jun 14, 2011 | Dishwashers
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Reset whirlpool front loader
Power shd be on. Right side of control panel, "end of cycle", hold this down for 3 seconds.
Mar 21, 2009 | Whirlpool Washing Machines
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Miele WT945 Front Load Washer / Dryer Logo
608 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
