Question about Sony Ericsson W850i Cellular Phone
Just a black screen
Ive had my phone for only about 3 months and recently i noticed the screen was flashing to the bright light to the standby light, i told my parents and my friend said hers did the same thing, but now the whole bloody screen has gone blank. i can still play my music but the whole screen is black.
  • 530 Answers
Hi im josh may i help you? Friend your phone appears flashing bright light then standby light. I diagnose this as a hardware problem particularly the flex connection from LCD to mainboard.If is difficlut to say that this is a software problem because you've said that you can operate the music and other pheriphrals.Because when software is corrupted or damage it will not make the whole phone for sure but is not so. I'm sure the connection poblem is the problem.maybe it just a disconnected or loosen connection problem. all you have to do is luuk for somebody know some electronic works then let him or you open the phone this just firmly attached or mount properl the connection of LCD and mainboard it will solve the problem for sure or you may do the job to the moble phone technicians in you neighborhood. if you need some assistance how to disassemble the phone you may log on to sonyericson.com. thats all friend good luck
Posted on Mar 07, 2009
The screen to my cellphone doesn't work.
sadly nothing lasts forever . might be time to bin it
Feb 28, 2017 | Samsung Trance SCH-u490 Cell Phone
I changed the batteries and continued to take photos when i noticed that the screen was flashing on and off and then going to standby mode. tried resetting back to default but screen still flashes. flash...
Hi Bill,
You are not using this flash like a sub-machine gun, right?
Is your reachargeable batteries older than 15 months?
Try this:
Set to low power on flash, set flash to manual.
Remove flash from hotshoe.
Fire the flash by pushing the flash button for 3 mins, same problem(s)?
atdlee@netzero.com
Jan 17, 2010 | Nikon Speedlight SB-600 TTL Flash
32" beko TV stuck in standby
Ur power board is dead.U need a new one.
Jun 21, 2009 | Beko 324250WN 28" TV
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Bright light on bottom of screen
sounds like your light engine. Very easy to replace.
Jan 14, 2008 | Toshiba 62HM95 62" HDTV
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
Sony Ericsson W850i Cellular Phone Logo
64 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
