Question about Toshiba 14" LCD Monitor
Screen keeps going bright
Whenever i start up my computer, 20-30 seconds later it goes super bright. it may be because i accidentally dropped it but i don't know. If anyone has the same problem and has a solution, i will be more than happy to read it. thank you.
  • whitehawk200 Jan 11, 2010
    Its ok, all I did was go into my ATI catalyst control center, went to the COLOUR menu and selected"Reactivate ATI colour controls"
    It's ok now, all i did was go into my ATI catalyst control center on my toolbar, go to the color section and clicked the "reactivate ATI color controls". My screen is fine now, thanks for your help anyway
  • 78 Answers
I am sorry but this means that the screen might be busted. the impact might have damaged the luminous controller inside the screen. You might need to find a replacement for the screen if that is happening.
I had a similar case where the screen was gng very bright but this was due to a cabling fault of the screen.
Posted on Mar 07, 2009
I had same problem, but went to the ATI Catalyst Control Centre and clicked on RESTORE TO FACTORY CONDITIONS. Hey Presto! I'm back to normal......No problem
Posted on Feb 03, 2010
I have the same problem. And I didn't drop my laptop. It started hapening after I installed a game.
Posted on Jan 11, 2010
Dell Inspirion 546 screen keeps going black
It sounds like a hardware fault, does it happen when the laptop is cold or does it start to go faulty after its been on a while, if it goes faulty after its been on a while, its more than likely that the fan cooler is all blocked up with dust, and will need to be cleaned. Hope this helps.
Nov 25, 2016 | Dell Computers & Internet
I constantly keep seeing "brightness 100"
Check out this link to the manual. It looks like your "On Screen Display" is possibly locked. This should help you unlock it if that's the case...
http://downloadcenter.samsung.com/content/UM/201002/20100208161857906/BN59-00992A-01Eng.pdf
Oct 31, 2011 | Samsung SyncMaster T220 22 inch Monitor
Whenever my Dell Precision M6300 is ever on maximum brightness, the backlight goes dark after 1-2 seconds. The screen is fully functional, but the backlight simply isn't working. I can get the backlight to...
guess there is an larger issue with your notebook.....
you need to get the backlite changed, if you have chanaged the lite then there is a compatibility issue with the screen and the invertor board that's behind the LCD screen.
or the system is not supplying the correct current to the backlite / invertor board
a HW tech guy may solve your issue
Nov 18, 2010 | Dell Precision M6300 Mobile Notebook
My 48 inch plasma screen goes black whenever something im watching goes bright, like a white flash on a show will make the screen go black and audio still on. turn the t.v. off then on and it works again...
The internal fan can fail.
Before you invest money call on a TV repair man,place a small fan near the power supply. (within 3 inch from the power cord or the nearest vent from the power cord)
This will keep the power supply cool and keep the therm protection circuit from tripping,
When you has time,inspect the internal fan for movement.
Jul 11, 2010 | Emerson Televison & Video
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Screen brightness keeps going down.
its because it has gone into power saving mode, you need to go into the power/battery settings and set the brightness at 100% and then choose that setting as default.
Sep 06, 2007 | Toshiba Satellite M30X Notebook
Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Jan 31, 2007 | LG Flatron L1715S 17" LCD Monitor
Computers & Internet Logo
694 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
