Question about Zanussi ZWF1430W Front Load Washer
Error 10 message
My Zanussi Jetstream washing machine gets half way through its cycle and then decides to stop, displaying the Error 10 message. As we seem to have mislaid the instruction book, we would be very grateful if you could provide us with a cure for this problem.
  • 44 Answers
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Posted on Mar 21, 2009
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
Error code E35 what is this?
switch off the elec remove lid and check the pressure switch tubing is not been rubbing against the side of the mach and wearing a tiny hole into the tubing .there is sometimes 2 tubes looking from the rear of the mach they are at the left handside not the best place i normally take the rear half of the mach off to gain access .also it only needs apin hole or less to cause bother take care hope this helps
May 06, 2014 | Washing Machines
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
ZANUSSI JETSTREAM, CODE E20 appears with every wash near the end of cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out
If still the problem persists then the problem is with the draining pump.Replace it and this wont come again
Thank You
Sep 09, 2010 | Zanussi Washing Machines
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Noisy during some parts of the cycle
it could be the concrete ring situated at the front of the machine. i had the same problem with mine 2 years ago.
Jul 29, 2008 | Zanussi FJD1266W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
479 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
