LG1717S powersaving mode problem!
My new LG1717S monitor goes into powersaving mode the second i turn it on. First it goes onto a green light and says powersaving mode and then the message goes off and it goes to an orange light. Then nothing happens.
  • 1 more comment
  • joelp1994 Mar 07, 2009
    I can't disable the power saving mode because my computer won't turn on properly!
    guys i cant load it because when i turn the monitor on it says powersaving mode and turns to an orange light cant even get on the computer
  • OldChris Apr 02, 2009
    Exactly the same problem here. The LG web-site seems singularly useless for drivers for this particular model.
  • 78 Answers
Have you tried to disable the pwer saving mode and see what happens. What operating system do you have on this laptop please ?
Posted on Mar 07, 2009
  • Mr fix.it Mar 07, 2009
    Why dont you try and load the pc in safe mode and try and disable this from within this mode.
  • Mr fix.it Mar 08, 2009
    Does the menu of the monitor respond to any buttons that you press on the monitor if so try and find the option to master reset it.
Dell E228WFP keeps entering powersave mode
disconnect all the cables from the back of the monitor except the power
you would see a test screen
if it still go to power safe while you are in the test page you monitor cud be bad better buy a new one as usually repairs are expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Moved my pc and now the green light is flashing on the monitor. won't turn on. help! manual says to hit any button on keyboard or use mouse and it will come out of powersaver mode. mine does not
If you've moved your whole PC recently then you might need to make sure that the VGA cord is connected to the correct output on your computer and is screwed on tight. If that doesn't work then try replugging it.
Mar 01, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
When i turn my monitor on my monitor goes into power save why
it might very well be an issue with the new PC's video hardware. If the monitor gets no signal within the first few minutes then it will automatically go into power save mode. Also, just as a troubleshooting idea, recheck the vga/dvi connection on the back and make sure it is seated well. You might also have a bad monitor. One week old equals exchange.
Aug 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Second monitor - 'power save' mode.
Firstly, you can try to switch the second with the first monitor. Secondly, use only the second monitor as a main monitor and check that if there is still a problem or not. It might be because of BIOS. You can check and update BIOS with your computer manufacturer.
Feb 20, 2008 | LG L1918S-BN (Black) Monitor
URGENT Big project due...Monitor won't stay on...light goes yellow after initial message c below
check the cable which connects from the monitor to cpu is connected properly... if it s not connected properly this problem occurs.. just reconnect it ... ur problem will be solved...
Dec 03, 2007 | Sony SDM-HS73P 17" LCD Monitor
Computers & Internet Logo
535 people viewed this question
David Payne
David Payne
