Question about JVC GM-V42 42 in. Plasma Television
Hi!Mr.kay here! require bin file for the 24c64 eeprom on digital board of jvc gm-v42s unit is stuck in stby. thanx guys my email is mrkay@topmail.co.za unit comes from dubai cant get assistance here. very urgent.
2 Suggested Answers
  • 5 Answers
SOURCE: I have lost my remote for JVC TV GM-V42S. Where
I contacted JVC professional to find out the model number for my JVC GM-V42E. Once you have the model number, contact JVC and order a new one or google the product number and try using websites that are dedicated to providing remote controls, I was able to get one from avukltd.com a little cheaper and more quickly than JVC said they would have the product in stock.
I also found the remote control product number on the bottom of the plasma screen.
Posted on Jun 24, 2010
Hi there, i have a baird lcd model j047baird\r\nthe fault i am having is, it stuck in stby. power supply look fine all voltage is there. if i disconnect the lead j5 from main board to invertor the screen...
there is 2 problems that makes this tv have standby fault.. so here they are,!
1.)main av board ---the 8 leg eeprom loses programing just under LVD CABLE TO SCREEN -£14.99 from a guy or if you can program yourself 4.99 for the flash to reprogram,.
2.)POWER SUPPLY FAULT IS MLT199TL PSU. (UA4)AREA, SG3525AN (16 leg) Regulating pulse width modulator.
the first fault all votage at psu will be there ,, 5v / 12v / 24v
the second fault psu will have 5v standby but no 12v or 24v this will stop the secondary from fireing up.. hope this helps.
Jul 31, 2011 | Televison & Video
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
I have lost my remote for JVC TV GM-V42S. Where can I get one? Thx Rod
Apr 05, 2010 | JVC GM-V42 42 in. Plasma Television
I need code for 2000 mitsubishi montero sport radio i changed battery and now the radio is asking for a code, no one keep the code that came with the vehicle. the numbers i got off the radio are, mu...
call mits elec at 8004244707 or panasonic tech hotline with model and serial number of your unit. They can furnish you with the original security code
Jan 13, 2010 | 2000 Mitsubishi Montero Sport
This console has been banned for violations of the Terms of Use. To protect the Xbox LIVE service and its members, Microsoft does not provide details about console bans. There is no recourse for Terms of...
You must do the following to get access for free:
requires a virgin xbox that has not been banned (a friend's) and somewhat knowledge about computers.
Banned Xbox Live Fix - New EEPROM ' (Old Tutorial)
To get unbanned you need to purchase a new xbox EEPROM(pal or ntsc). Steps for installing it are listed below. IT WORKS. Just make sure your orginal MS info is correct and your modchip is turned off.
GETTING THE EEPROM FILE FROM THE UNBANNED XBOX
(TO INSTALL YOUR EEPROM, MAKE SURE YOU ARE USING CONFIGMAGIC FINAL* ALL OTHER VERSIONS ARE BUGGY AND WILL CAUSE PROBLEMS. ALSO, DO NOT USE THE SOFTWARE: EEPROMER)
[This is only if you want to backup your original eeprom file]
1. In EvolutionX, do the "Backup" command in the Utilities menu. It will generate files about your Xbox specs.
2. FTP in your Xbox, or use a file manager tool, and in C:Backup, you will find a file called EEPROM.BIN
3. FTP that to your PC HD or remember its location for future reference.
SETTING UP THE FILE FOR CONFIGMAGIC FOR THE BANNED XBOX:
1. Once you have Configmagic loaded onto your HD or on your PC, there will be a directory in it called DATA.
2. Move the EEPROM.BIN file, the new unbanned EEPROM you purchased, into that DATA directory, overwriting the EEPROM.BIN file that is already there.
3. If you are making a Configmagic CD, you can now make the ISO of it and burn it. Xbox HD users, don't worry.
RUNNING CONFIGMAGIC:
1. Load up Configmagic.
2. A warning screen will be shown, press "A" to bypass it.
3. When Configmagic finally loads, it will show your current EEPROM on your Xbox. Make a note of the DVD KIT ZONE and VIDEO AND XBE REGION information. "NTSC, Region 1" for US Xbox gamers "PAL, Region 4" for UK Xbox gamers
4. Select "LOAD XBOX EEPROM" in the menu.
5. Select "UNLOCK HD" in the menu.
6. Load the EEPROM.BIN file in the DATA directory by choosing "LOAD EEPROM FROM .BIN FILE"
7. If you see that the VIDEO AND XBE REGION information is different, you MUST change it. Go into the menu and choose "ON-THE-FLY EDIT EEPROM". Change the VIDEO AND XBE REGION number to the proper information of your former EEPROM.
8. Now, select "UPDATE XBOX EEPROM" in the menu.
9. Your Xbox's EEPROM will now be updated with the file in the DATA directory.10. In the menu, select "LOAD XBOX EEPROM". You will notice your EEPROM is now different! Success.
11. Select "LOCK HD" from the menu.
12. Select "EXIT CONFIGMAGIC" in the menu.
IMPORTANT TIPS:
- If you were using the XBOX DVD KIT to play DVDs, and the Xbox gives an error about region, load up Configmagic and change the DVD KIT ZONE number to the number of your previous EEPROM. UNLOCK the HD, choose "ON-THE-FLY EDIT EEPROM" in the menu and simply change the DVD KIT ZONE number. Then, UPDATE XBOX EEPROM and LOCK HD. Exit Configmagic.
- You can view any Xbox EEPROM using your PC by getting Liveinfo PC program. It will show all the details of an EEPROM.BIN file. You might find it easier to edit any possible changes to your DVD KIT ZONE or VIDEO AND XBE REGION using the program, rather ON-THE-FLY EDIT EEPROM in Configmagic.
- Sometimes, with a PAL EEPROM, your Xbox's time might be wrong or video settings will be different. Go into the MS dash and change the settings to the way you seem fit.
Special Notes:
- If you were banned with your original eeprom, once you replace your eeprom, you will need recover your account. To do this, simply select the account recovery option. Once this is done, you will need to verify some personal information in order to retrieve your account.
Nov 07, 2009 | Microsoft Xbox 360 Console
950 system board
Usually, at least on the Lexmark products I am most familiar with, a 950 error had occured when a printer had the systemboard replaced and the repair tech failed to update the new systemboard to reflect the correct information contained the printer's NVRAM.
From a software perspective, this should never accidently happen. Either the NVRAM on the printer is blown or the systemboard memory of the matching terms has been cleared.
Again, not a trivial endevor.
At this point, I'd suggest a service call to get the diagnostics run against the printer. You may have to replace the systemboard.
Don
May 25, 2009 | Lexmark E340 All-In-One Laser Printer
I NEED SOFTWEAR FOR MY VIDEO CAMERA
how to conect jvc GR-850AG Mini DV digital camcorder
Oct 16, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Jvc gz-mg330ek--will not power up--will not switch on
hi.
thank you for your email.
i have since sold the camcorder on--no more problems with it.
best regards
mr.j.b mc dermott---brunhouse.
May 28, 2008 | Video Cameras
Sapphire ATI RADEON 3850 PCIE 512mb---> Having problems with card driver. PC slows down whenever such driver is installed, both from supplied driver cd and downloaded driver from sapphire/ati website. I am...
JoBal,
The main problem is meeting system requirements for this high-end card. Please see the requirements list below and let me know if you are up to par.
Requirements (taken directly from their website)
  • PCI Express based PC is required with one X16 lane graphic slot available on the motherboard.
  • 1GB or greater system memory for better performance.
  • 450Watt or greater power supply with 75 Watt 6-pin PCI Express power connector recommended.
  • For ATI CrossfireX: 550 watt power supply or greater with two 6-pin connectors.
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • Installation software requires CD-ROM drive.
  • DVD playback requires DVD driver
  • Blu-ray/HD DVD playback requires Blu-ray/HD-DVD drive and playback software.
  • For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 3850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per board are required.
Take care!
Feb 24, 2008 | Computers & Internet
JVC GM-V42 42 in. Plasma Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
